Commando FM-5005
auto5
Member - Posts: 6
Posted: September 20, 2005 at 4:43 PM / IP Logged
Hi, I am having problems with my alarm system, Commando 5005. Remote start works fine, door locks work fine, heres problem.  When I arm alarm and set it off I have flashing parking lights but no siren, also when I try to go into program mode, the LED just stays on, and it will not chirp.  Found I cannot program second remote which is how I found out the alarm was not working properly.  Does this sound like it is time for a new siren, and will a bad siren cos the alarm not to go into program mode. When I turn the ignition on, the LED blinks three times one time and four times for four times, I do not know what that would mean, any help would be appreciated, thank you very much and have a great day.
blazeronspokes
Copper - Posts: 102
Posted: September 20, 2005 at 8:07 PM / IP Logged
check the ground on the siren.
Moderator - Posts: 12,488
Posted: September 21, 2005 at 7:21 AM / IP Logged
Check your siren output for (+) when the lights flash. If your getting a (+) signal from the siren output off the alarm harness, check to see if you have continuity between the siren and the CPU incase the wire was cut or damaged. Next check to be sure that the ground is good off the siren and the alarm system.
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
