odyssey 01 defrost
patmar
Copper - Posts: 69
Posted: October 14, 2005 at 8:45 PM / IP Logged
i guys ,i'm try to install rear defrost on my remote start. i'm use the trunk channel on my autostart as-1725 but check back of hacv and not find the wire. if you have the infos for rear defrost on honda odyssey lx 01 (not the digital hacv) thanks for help
pat
mrcllusb
Copper - Posts: 489
Posted: October 14, 2005 at 10:01 PM / IP Logged
I looked at the install manual for this alarm,and it shows that there is an accessory relay that i belive can be used for your rear defroster..
"ole blake"
thepencil
Gold - Posts: 1,526
Posted: October 14, 2005 at 10:18 PM / IP Logged
Add a relay and make the connection using the Green wire on the main harness and set the jumper on the starter unit to 2nd accesory. At the deforger switch there is a yellow/brown wire (negative). Test that out it should be there and will work.
Be careful whose advice you buy, but be patient with those who supply it.odyssey 01 defrost -- posted image.
