05 dodge caravan remote start
dereck
Member - Posts: 28
Posted: October 02, 2006 at 6:29 PM / IP Logged
Just wondering a couple things, on the 05 caravan the wires in the ignition harness are like 18 guage and the remote start has like 16 guage. Is it ok to hook these up?
And on the door locks, if i use relays do i need to hook up resistors to?
shaggy12volt
Copper - Posts: 164
Posted: October 02, 2006 at 7:24 PM / IP Logged
run your power wires to the battery do not use the lt.blue/red at all can not handlle the pull from the remote start
as for the dor lock yes you do read the info below
WIRING INFORMATION - DODGE / CARAVAN / 2005 / Remote Start
12voltslt. blue/red (10A) + ignition harness
Starteryellow + ignition harness
Second StarterPURPLE / brown - ignition harness
Notes: The second starter wire is negative trigger thru a 180 ohm resistor. MUST use a relay. Refer to DirectFax document 1083 for wiring information.
Ignitionpink/white + ignition harness
Second IgnitionN/A
Third IgnitionN/A
Accessorynot required for remote start
Second AccessoryN/A
KeysenseN/A
Power LockPURPLE / dk. green - BCM, white plug, pin 21
Notes: Lock is negative trigger thru a 5.3K ohm resistor. Unlock is negative trigger thru a 2.0K ohm resistor. MUST use relays.
The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Can also use Directed 456L interface modules.
Power Unlocksame as power lock wire
Lock Motortan/white 5wiBCM, green plug, pin 10
Notes: The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Unlock Motortan/lt. green 5wiBCM, green plug, pin 28
Parking Lights+WHITE/ brn (L), WHITE/ org (R) + driver kick, harness to rear
Parking Lights-WHITE/ brown - switch or BCM, gray plug, pin 21
Notes: The parking lights are negative trigger thru a 2.1K ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch. See DirectFax document 1082 for wiring information.
HazardsWHITE/ dk. blue - switch or BCM, gray plug, pin 31
Turn Signal(L)wht/lt blu (F), wht/dk grn (R) + BCM, green plug, pins 1, 2
Turn Signal(R)WHITE/ tan (F), WHITE/ brown (R) + BCM, green plug, pins 3, 4
Reverse LightWHITE/ lt. green + BCM, green plug, pin 9
Door Triggersee notes - BCM, white plug
Notes: The driver door trigger is purple in pin 6, the passenger door is PURPLE / white in pin 7, the left sliding door is PURPLE / gray in pin 8, and the right sliding door is purple / YELLOW in pin 5. Use all four wires and diode isolate each. Also have to diode isolate from the BCM. Refer to DirectFax document 1076 for wiring information.
Dome Supervisionyellow/brown or yellow/white + BCM, white plug, pin 33
Trunk/Hatch PinPURPLE / orange - BCM, white plug, pin 29
Notes: A diode must be placed inline on this wire to avoid problems with the dome lights and parking lights.
Hood PinPURPLE / lt. blue (export model) - BCM, white plug, pin 30
Trunk/Hatch ReleasePURPLE / tan - BCM, green plug, pin 6
Notes: Hatch release is negative trigger thru a 1.69K ohm resistor. MUST use a relay.
Power Sliding DoorPURPLE / dk. blue - BCM, white plug, pin 1
Notes: Left power sliding door is negative trigger thru a 1.5K ohm resistor. Right power sliding door is negative trigger thru a 2.7K ohm resistor. MUST use relays.
Factory Alarm Armarms on lock with door open
Factory Alarm Disarmfactory remote only
Disarm No Unlockwith ignition and Sentry Key
TachometerNOT BROWN / white ac ign coil pack or any fuel injector
Wait to startN/A
Brake WireWHITE/ tan + brake pedal switch
Parking Brakedk. GREEN / WHITE - parking brake switch
Horn Triggerdk. GREEN/ purple - steering column
Memory Seat 1PURPLE / brown - BCM, green plug, pin 24
Notes: Memory seat 1 is negative trigger thru a 6.8K ohm resistor. Memory seat 2 is negative trigger thru a 2.1K ohm resistor. MUST use relays.
Memory Seat 2same as memory seat 1 wire -
Memory Seat 3N/A -
05 dodge caravan remote start -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Sentry Key
Part #: 556CW
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on SXT models. Optional on SE models.
Door Lock Interface
Required:
Yes
Type:
Multiplex
Part #: 456LW
Notes:
Smart Starter Kill Relays:Relay Type:
Starter Relay
Engine compartment fusebox, Driver side
Part #: 6401A
The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
dereck
Member - Posts: 28
Posted: October 03, 2006 at 8:23 PM / IP Logged
So do I understand this corectly, This is a 5 wire Alt 12V Positive door locks so I can hook this up as the diagram shows. Spliting the lock wire and unlock wire for the motor and run it through the relay (30 and 87a). This Should work?
And were do I find DirectFax document 1083?
My email is dereckdaniels@hotmail.com if someone could send it to me thanks so much.
shaggy12volt
Copper - Posts: 164
Posted: October 03, 2006 at 9:32 PM / IP Logged
you have a one wire door lock system
Power Lock and Unlock  PURPLE / dk. green  -  BCM, white plug, pin 21
The Shagmaster
wrxsti161
Copper - Posts: 62
Posted: October 06, 2006 at 10:10 AM / IP Logged
this is a (-) triggered multiplex lock/unlock system.  You will need to use 1 relay. This never fails me:
86 (-) lock in
85 +12v
87 5.3k ohm resistor to ground
30 cars lock-unlock wire (purple dk.green)
87a (-) unlock wire to 2.9k ohm resistor to remote start unit
David
MECP Basic Installer Certification
shaip99
Copper - Posts: 112
Posted: October 09, 2006 at 5:38 AM / IP Logged
cool idea but your unlock wire isnt actually relayed it is straight from the starter unit i would suggest you use two relays and do it properly
"Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd
all run around in a darkened room munching pills and listening to repetitive
music."-Kristian Wilson, Nintendo Inc.
snotdobbs
Copper - Posts: 148
Posted: October 10, 2006 at 8:10 PM / IP Logged
its highly unlikely that your remote start is gonna have more than a 10 amp draw since everything in that vehicle is low current......but smack me if im wrong
Mike M2
Platinum - Posts: 2,652
Posted: October 10, 2006 at 8:46 PM / IP Logged
I've done tons of RS in these vans and always use power from the ignition switch. Nothing is high current if you use negative park lights and it works fine...
Mike M2
Tech Manager
CS Dealer Services
shaggy12volt
Copper - Posts: 164
Posted: October 10, 2006 at 8:56 PM / IP Logged
Why do you think they usely put two 30 amp fuses on most remote starters. have looked at how skiny them wires are i wouldint want to take any chance
The Shagmaster
snotdobbs
Copper - Posts: 148
Posted: October 10, 2006 at 9:15 PM / IP Logged
just because your amp has a forty amp fuse in it does that mean your always gonna be drawing 30 or 35 amps....youll be fine using that power lead......i will suggest staying away from the 2 amp circuit powering the new dodge rams key cylinder....you will likely be drawing more than 2 amps at a given point but come on 10 amps to activate low current switches to a pcm?  unlikely....your parking lights are negative and that relay might draw something but nothing to be concerned about.....if your adding relays for lockunlock sliding doors power rear hatch.....then yah maybe your gonna draw more than ten amps if you activate every option while your remote starting with every accesory in the vehicle on........but thats an unlikely situation....besides just use a combo data interface and youll nevr have anything to worry about.......
just my two sense........
though i am surprised that someone agreed with me about this...........mikem2...i figured idget pm'd to never post here again.......
Tuesday, June 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
