1999 Grand Am, Autostart starter
gavin9797
Copper - Posts: 106
Posted: October 25, 2006 at 10:27 PM / IP Logged
Hey everyone,
A friend at work is trying to install this remote starter, in said car. I dont know the model number on the starter I forgot to ask. He also has the 555L bypass.
After reading the searched forum he seams to be having the same problem as everyone else. The vehicle shuts down after startup.
Without knowing the starter model, any general suggestions for remedy?
Thank you.
Hymer
Silver - Posts: 695
Posted: October 25, 2006 at 11:38 PM / IP Logged
Fuel pump might not be fireing up.... grey in the drivers kick. pulses 1 sec before crank, stops during crank, then goes hot after startup....
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
green6767
Copper - Posts: 209
Posted: October 26, 2006 at 8:28 AM / IP Logged
Sounds like a passlock II issue. When that isn't bypassed correctly, it will shutdown right after startup when remote started. I assume the car starts fine with the key? Does it remote start with the key in the ignition?
Shaun, we are the same height, that is neat!
12V Installation Technician for Honda, Dodge, Chrysler, Toyota and Jeep.
Moderator - Posts: 12,488
Posted: October 26, 2006 at 11:01 AM / IP Logged
Make sure that the status output wire/ground when running wire is sending a (-) signal to the 555L and also make sure that the 555L is hooked up properly and learned the R-Code properly as well.
Sunday, November 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
