wiring for ’05 Sunfire, remote start
dansonic
Posted: November 13, 2006 at 11:45 AM / IP Logged
just wandering if and how to deal with Passlock upon
installing an Astro Start on an 05'Sunfire and would also like to have wiring diagram. It would greatly apreciated. thanx!
DDD       A    NN    N
D    D    A A   N N   N
D    D   A A A N   N N
DDD   A      A N    NN
Twelvoltz
Platinum - Posts: 2,384
Posted: November 13, 2006 at 12:52 PM / IP Logged
DEI's Information:
DIRECTWIRE™ WIRING INFORMATION - PONTIAC / SUNFIRE / 2005 / Remote Start
[PRINT THIS PAGE]
12volts      red (x2)(common 50A)       +       ignition harness
Starter      yellow       +       ignition harness
Second Starter      N/A
Ignition      pink       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      orange       +       ignition harness
Second Accessory      brown       +       ignition harness
Keysense      lt. green       -       ign harn or BCM, brown plug, pin B12
Notes: The BCM is above the driver kick panel.
Power Lock      lt. blue       +       BCM, purple plug, pin A4
On vehicles without keyless entry, the door lock wires are just located in either kick panel. They are 5wi (Type C), and mastered from the passenger door lock switch.
Power Unlock      white       +       BCM, purple plug, pin A3
Lock Motor      gray       5wi      driver kick or door lock relay
Notes: The door lock relay is above the passenger kick panel.
Unlock Motor      tan       5wi      BCM, purple plug, pin A6
Parking Lights+      brown       +       BCM, blue plug, pin A1
Parking Lights-      N/A
Hazards      same as turn signal wires
Turn Signal(L)      lt. blue (F), yellow (R)       +       turn signal switch
Turn Signal(R)      dk. blue (F), dk. green (R)       +       turn signal switch
Reverse Light      lt. green       +       driver kick, harness to rear
Door Trigger      lt. GREEN/ black and lt. blue       -       BCM, purple plug, pins A7 and A8
Notes: The driver door trigger is lt. GREEN/ black, and the passenger door(s) is lt. blue. Use both wires and diode isolate each.
Dome Supervision      white       -       BCM, brown plug, pin A1
Trunk/Hatch Pin      ORANGE / black       -       BCM, blue plug, pin A4
Hood Pin      N/A
Trunk/Hatch Release      BLACK/ white       -       BCM, blue plug, pin B4
Power Sliding Door      N/A
Factory Alarm Arm      factory remote only
Factory Alarm Disarm      factory remote only
Disarm No Unlock      with ignition and Passlock
Tachometer      white or orange       ac       ignition control module
Notes: The Ignition Control Module is on the driver side top of the engine.
Wait to start      N/A
Brake Wire      white       +       brake pedal switch
Parking Brake      lt. blue       -       BCM, blue plug, pin B2
Horn Trigger      black       -       BCM, brown plug, pin B7
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Passlock II
Part #: 556LW
Alternate Part1 #: 555LW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: The Passlock II wire colors are yellow, black, and white (not used).
Door Lock Interface      Required:
No      Type:
N/A
Part #: N/A
Notes:
Combo Interface      Required:
Yes      Type:
Data Bus
Part #: 1700G
Alternate Part1 #: 457GW
Notes: Can use the 1700G or 457GW to bypass the Passlock II, but it will not control the door locks on this model year.
Smart Starter Kill Relays:      Relay Type:
Crank Relay      Location:
Engine compartment fusebox, Passenger side
Part #: 6402A
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
dansonic
Posted: November 13, 2006 at 3:21 PM / IP Logged
I thought i had read somewhere that there was a way to
bypass passlockII system by cutting a yellow wire and testing the resistance with an ohm meter and installing
an in line resistor instead of buying an interface module.Was i dreaming or what!!!
And by the way thanx Twelvoltz...
you've been a great help.
Dansonic
DDD       A    NN    N
D    D    A A   N N   N
D    D   A A A N   N N
DDD   A      A N    NN
Tuesday, June 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
