2005 Dodge Ram 1500 ST, Ultra Start U4266m
mechwarrior1221
Posted: November 28, 2006 at 3:56 AM / IP Logged
I have a dodge ram 1500 st 4x4 2005 with 6 speed manual transmission . recently i connected an ultra start system, model u4266m fcc aproved. thats what the box said. I used as reference wiring diagrams for the truck  from bulldog security. for the remote start  i used the installation guide. all connections were made accordingly but the truck didnt start.  i noticed there was 2 ignition wires and 3 accesory wires. i used 2 relays for ignition because the "brain" only came with one ignition wire. also 2 more relays  for two of the accesory wires. the third accesory wire was spliced to a programable output by switching a pin in the box to accesory. all other connections to brake, clutch , tach, hood, and parking lights.  the ultra start box was reacting to the signal of the pager but the relays that i connected were not. i double checked my relay connections and tried again and i had the same results, nothing.  so i went for a beer.
i have reached a good stopping point until i gather more information about this system. its a new truck and i dont want to mess it up. is there a connection that you would try diffrent or maybe i connected the wires wrong? a good advice would be taken. if more info about this is needed let me know.
thanks to all of you.
KarTuneMan
Platinum - Posts: 7,056
Posted: November 28, 2006 at 8:49 AM / IP Logged
This is NOT the ideal vehicle to "learn" how to install a remote start on. You have everything against you, although at least it's NOT a diesel.
A BCM is a spendy way to get an education.... I would strongly suggest getting some help. If you choose to continue, heres another tech sheet.
Wire/Function Colour Location/Description Polarity
PASSIVE ANTI-THEFTYESTRANSPONDER SEE NOTES
12 VOLTSBlue/redIgnition switch harness +
This wire should not be used for remote start or alarm installations. It is recommended that you run power to the fusebox or to the vehicle's battery.
IGNITIONPink/whiteIgnition switch harness +
ACCESSORYViolet/brownIgnition switch harness -
This wire uses ground with resistors to activate Accessory (560-ohm) and Second Start (150-ohm). See the provided diagram for wiring instructions.
STARTERGREEN/ YELLOWIgnition switch harness +
STARTER 2Violet/brownIgnition switch harness -
KEY SENSEViolet/brownIgnition switch harness
Violet/brown goes to pin C4-13 of instrument cluster unit; WHITE/ orange return wire is found at pin C3-11
TACH SIGNALDk.Blue/grayAt PCM on pass. Side firewall under hood AC
DIESEL TACH SIGNALDk.blue/grayAt ECM on driver's side motor in first plug AC
FUEL INJECTOROpposite of Tan/whitAt any injector on engine AC
LOCKViolet/greenIn driver's kickpanel -
Lock is (-) through 800-ohm resistor. Unlock is (-) though 330-ohm resistor.
UNLOCKViolet/greenIn driver's kickpanel -
DOORPINSEE NOTES
Door triggers are independent and can be found behind the instrument cluster. Violet (Driver's door), Violet/white (pass.door), Violet/gray (left rear door) and Violet / YELLOW (right rear door). All 4 wires are (-) and should be diode isolated.
FACTORY ARMOEM REMOTE ONLY
FACTORY DISARMOEM REMOTE ONLY
The alarm will disarm automatically for remote start with proper IMMOBILIZER bypass.
BRAKESWITCHWHITE/ tanAt switch above brake pedal +
PARKLIGHTSWHITE/ greenAt light harness switch -
Use a 1100-ohm resistor inline to activate parking lights.
HAND BRAKEGREEN / WHITEAt switch on handbrake lever -
HORNGREEN/ violetAt steering column
KarTuneMan
mxxmikexx
Silver - Posts: 796
Posted: November 29, 2006 at 10:12 AM / IP Logged
Also for the parking lights... if you use the 1.1K resistor the headlights will also trigger, i've found using a 1.8K resistor will only trigger the parking lights. And ive also found on trucks WITHOUT factory foglights, if you use the 1.1 K you will also trigger the foglight dummy light on the dash.
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
