where to get a 1500 ohm resistor?
juanr8600
Posted: December 11, 2006 at 7:34 PM / IP Logged
does any one know were i can buy or make a 1500 ohm resistor couse i got 2003 chey malibu and i need to unlock the doors......
john ogrady
Copper - Posts: 82
Posted: December 11, 2006 at 8:26 PM / IP Logged
Any good electronics store should have them.But to buy one resistor ,not likely you would have to buy a pack of 5 or 10 whatever the minimium is.To get just the one you need see if you can talk to one of  techs in the repair dept.I like buying a assortment pack of approx 100 resistors of different values for about $4.00.As time goes on you find a need for the other values and helps from running around looking.
KarTuneMan
Platinum - Posts: 7,056
Posted: December 12, 2006 at 8:59 AM / IP Logged
In a pinch......you can series or parralel a number of resistors to get the value you need....The tolerance changes though.
dskemaite
Member - Posts: 25
Posted: December 12, 2006 at 9:27 AM / IP Logged
radio s
eddddddddddddiiiiiiiiiieeeeeeeeeeeee
Sunday, June 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
