oem alarm mazda 6
baldur
Member - Posts: 9
Posted: March 04, 2007 at 1:47 PM / IP Logged
does mazda 6 have any more factory alarm then the imoblizer system for the key ??
KarTuneMan
Platinum - Posts: 7,056
Posted: March 04, 2007 at 2:36 PM / IP Logged
Yes they do!
FACTORY ARM Arms with lock wire
 FACTORY DISARM Disarms with unlock wire    -
master5
Silver - Posts: 1,123
Posted: March 04, 2007 at 2:37 PM / IP Logged
Yes it has a factory alarm.
The immobilizer for the key is NOT an actually an alarm..it is an immobilzer (does not allow the vehicle to start without the proper key code read at the ignition switch antenna) and the Mazda 6 has that as well.
baldur
Member - Posts: 9
Posted: March 04, 2007 at 6:34 PM / IP Logged
ok sorry i am new in this :) there is only one wire on the alarm i have to disarm factory alarm were do i connect it ?
also having a hard time understanding how to connect the power locks i know it has a negative trigger but not getting how to do it right ??
i have a fox alarm and remote start that i got on ebay
master5
Posted: March 04, 2007 at 7:30 PM / IP Logged
Yeah..you are new to this..but hey..we all started somewhere. Let us know the year of the mazda 6 and we will post a diagram for you.
Hows that for service?
I have a slight concern about 2 things...1) you got it on ebay...and 2) it's a brand I never heard of..and I have been in the business for over 15 years.
But whatever..we will walk you through it..don't worry
baldur
Member - Posts: 9
Posted: March 05, 2007 at 2:40 AM / IP Logged
here it is http:///.com/LCD-CAR-ALARM-START-STARTER-2-REMOTE-MANUAL-OR-AUTO_W0QQitemZ150096434034QQihZ005QQcategoryZ94832QQrdZ1QQcmdZViewItem
think that omega or something makes them.
Thanks for the help so far !
master5
Posted: March 05, 2007 at 10:47 AM / IP Logged
also need the year of  your vehicle as there may be some difference in the electrical systems from one year to another.
baldur
Member - Posts: 9
Posted: March 05, 2007 at 1:29 PM / IP Logged
it is 2004 wagon 4 cyl 2.0 European model !!
master5
Posted: March 05, 2007 at 1:54 PM / IP Logged
My source only lists a mazda 6 for that year..doesn't specify if wagon or euro version but see if this helps anyhow....good luck. If you need further help on how to do the door lock setup let me know and I'll send a diagram.
The doors lock and unlock through the same wire. To lock you will use a resistor to ground with a relay..to unlock you use another relay but send a ground direct.
12volts  black (40A), BLACK/ yel (30A)   +   ignition harness
Starter  BLACK/ blue   +   ignition harness
Second Starter  N/A
Ignition  blue   +   ignition harness
Second Ignition  N/A
Third Ignition  N/A
Accessory  BLACK/ red   +   ignition harness
Second Accessory  BLACK/ white   +   ignition harness
Keysense  WHITE/ blue   +   ignition harness
Notes: Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
Power Lock  lt. green   -   driver kick or door lock module
Notes: Lock is negative trigger thru a 1000 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
The door lock control module is located above the passenger kick panel.
Power Unlock  same as power lock wire
Lock Motor  RED / blue   5wi  driver kick or door lock module
Notes: The door lock control module is located above the passenger kick panel.
Unlock Motor  RED / green   5wi  driver kick or door lock module
Parking Lights+  lt. GREEN/ black   +   driver kick, 14 pin plug
Parking Lights-  RED / white   -   headlight switch
Hazards  blue/orange   -   switch or door lock module
Turn Signal(L)  WHITE/ black   +   turn signal switch
Turn Signal(R)  WHITE/ red   +   turn signal switch
Reverse Light  RED / yellow   +   driver kick, 14 pin plug
Door Trigger  GREEN/ orange   -   driver kick or door lock module
Dome Supervision  yellow/black   -   driver kick or door lock module
Trunk/Hatch Pin  brown   -   driver kick or door lock module
Hood Pin  gray/red   -   pin switch or theft module
Notes: The theft-deterrent control module is located in the center console.
Trunk/Hatch Release  yellow   -   switch or door lock module
Power Sliding Door  N/A
Factory Alarm Arm  blue   -   driver kick or door lock module
Notes: Meter this wire while turning the key in the driver door key cylinder.
Arm is negative trigger thru a 1000 ohm resistor. Disarm is a straight negative trigger. MUST use relays.
Factory Alarm Disarm  same as factory alarm arm wire
Disarm No Unlock  use key sense wire
Tachometer  NOT blk/wht or grn/stripe   ac   any ignition coil or coil pack
Notes: On the 4 cyl models use the wire that is NOT BLACK/ white. On the 6 cyl models use the wire that is NOT GREEN/ stripe.
Wait to start  N/A
Brake Wire  GREEN/ YELLOW   +   brake pedal switch
Parking Brake  brown   -   parking brake switch
Horn Trigger  PURPLE / white   -   switch or door lock module
Immobilizer Bypass  Required: Type:Transponder
