03 suzuki grand vitara, wiring
gkonitshek
Posted: May 01, 2007 at 10:38 PM / IP Logged
Anyone have a wiring diagram for the 03 Suzuki Grand Vitara for installing a Alarm/Remote Starter?
Twelvoltz
Platinum - Posts: 2,384
Posted: May 02, 2007 at 7:45 AM / IP Logged
DEI lists:
DIRECTWIRE™ WIRING INFORMATION - SUZUKI / GRAND VITARA / 2003 / Remote Start
[PRINT THIS PAGE]
12volts      WHITE/ green (60A)       +       ignition harness
Starter      BLACK/ red       +       ignition harness
Second Starter      N/A
Ignition      BLACK/ blue       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      yellow/black       +       ignition harness
Second Accessory      blue       +       ignition harness
Keysense      blue/red       +       ign harn or BCM, 16 pin plug, pin 13
Notes: The BCM (Body Control Module) is below the radio.
Power Lock      pink/black       -       BCM, 12 pin plug, pin 1
Power Unlock      pink/green       -       BCM, 12 pin plug, pin 7
Lock Motor      blue       5wi      BCM, 22 pin plug, pin 12
Unlock Motor      blue/white       5wi      BCM, 22 pin plug, pin 2
Parking Lights+      RED / yellow       +       BCM, 22 pin plug, pin 22
Parking Lights-      RED / blue       -       BCM, 22 pin plug, pin 9
Hazards      yellow/red       -       BCM, 22 pin plug, pin 17
Turn Signal(L)      GREEN/ red       +       turn signal relay, left of column
Turn Signal(R)      GREEN/ YELLOW       +       turn signal relay, left of column
Reverse Light      red       +       driver kick, harness to rear
Door Trigger      BLACK/ red       -       BCM, 16 pin plug, pin 16
Dome Supervision      BLACK/ red       -       BCM, 22 pin plug, pin 14
Trunk/Hatch Pin      common with door trigger wire
Hood Pin      N/A
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      pink       -       BCM, 12 pin plug, pin 2
Factory Alarm Disarm      pink/blue       -       BCM, 12 pin plug, pin 8
Disarm No Unlock      see factory alarm disarm
Tachometer      brown       ac       cluster or ECM, 35 pin plug, pin 4
Notes: The ECM (Engine Control Module) is behind the glovebox.
Can also go to any ignition coil and use the wire that is NOT BLACK/ white or BLACK/ orange. Can also go to any fuel injector and use the wire that is NOT blue/black.
Wait to start      N/A
Brake Wire      GREEN / WHITE       +       brake pedal switch
Parking Brake      RED / black       -       BCM, 16 pin plug, pin 5
Horn Trigger      blue/green       -       BCM, 22 pin plug, pin 4
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
No      Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
