alarm in 1996 cavalier
viper15230
Posted: October 16, 2007 at 3:16 PM / IP Logged
The siren triggers as soon as I plug the harness into the brain. Im not sure why I have only hooked up power ground ignition and the siren output at this time. I wouldnt think that would cause the siren to go off would it?
KPierson
Platinum - Posts: 3,527
Posted: October 16, 2007 at 3:22 PM / IP Logged
Some alarms trigger as soon as power is connected.  Once it is connected trying disarming the alarm.
Kevin Pierson
viper15230
Posted: October 16, 2007 at 3:28 PM / IP Logged
No response from the alarm with that method.
KPierson
Posted: October 16, 2007 at 3:37 PM / IP Logged
What kind of alarm is it?  Is there a manual override?  You may need to program the remotes to the alarm.  It should respond to the 'disarm' command from the remote.
Kevin Pierson
viper15230
Posted: October 16, 2007 at 7:00 PM / IP Logged
Its a K9 Sombra. I tried programming the remotes and the valet switch. Nothing would turn it off. Im stumped.
JWorm
Platinum - Posts: 2,208
Posted: October 16, 2007 at 7:35 PM / IP Logged
Try plugging in the alarm with the ignition turned on.
docsautomotive
Copper - Posts: 66
Posted: October 16, 2007 at 7:55 PM / IP Logged
also try hooking up the other wires first we do a lot of these types the sombra  green box
never stop
docsautomotive
Copper - Posts: 66
Posted: October 16, 2007 at 7:59 PM / IP Logged
also if all else fails try swapping the brain but before you plug any thing up make sure all your wire are connected do not plug the power harness firs  make it your last conection also your vallett switch needs to be pluge to program remotes and you should not need to do that they come programed
never stop
Moderator - Posts: 12,488
Posted: October 16, 2007 at 8:14 PM / IP Logged
Make sure that you have the (+) and the (-) from the siren hooked up properly. If the system rests the siren output wire at (+) and you have the siren grounded with the (+) wire going to the CPU, the siren will trigger instantly.
viper15230
Posted: October 16, 2007 at 9:00 PM / IP Logged
Well its not just the siren. Its the relay inside the box I can hear it clicking for the light outputs. I tried plugging it in with the ignition on, no different. Im not sure what you mean by everything else first.
