can a 30a relay handle the acc or ign?
wungun
Copper - Posts: 71
Posted: September 14, 2008 at 7:08 PM / IP Logged
I plan on using a relay for the ACC and a relay for the IGN circuits in my car...
Will 30A relays be sufficient?
Platinum - Posts: 12,488
Posted: September 14, 2008 at 7:23 PM / IP Logged
Yes
wungun
Copper - Posts: 71
Posted: September 15, 2008 at 12:09 PM / IP Logged
Velocity Motors wrote:
Yes
Thanks!
Getting closer to the push button start for the car. I've gone to a dual relay setup for the button, wherein one relay takes a momentary pulse (from the start button) and switches the other relay on and latches it, until the + or - is removed (stop button)...this will turn on one relay each for the IGN and ACC.
Using a simple timer to deactivate the Viper auto start (or maybe even just the standard brake pedal still) and also for push-and-hold for IGN only, without starting...
I've ditched the Allen Bradley latch relay for this simpler design...
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
