93 mustang, relay wiring, fan, water pump
bad notch
Posted: December 11, 2008 at 12:40 PM / IP Logged
Here is what I got.   I have a 93 Ford Mustang, I have an Electric Fan and Electric Waterpump setup on the motor and here is what I want to do:  Have the Fans and Pump turn on when the ignition is in the Key On/ Engine Running and off when the ignition is off.  I also want to be able to turn them on and off via toggle switch when the key is off so I can let my car cool down in the pits with nothing on except the fan and pump.  The Fan and Water Pump have ONLY  power and ground wires coming off of them since they are single speed.
What relay would work with this ?
What is the best way to wire this up ?
Thanks,
Mike
ckeeler
Gold - Posts: 1,461
Posted: December 11, 2008 at 3:18 PM / IP Logged
93 mustang, relay wiring, fan, water pump -- posted image.
bad notch
Posted: December 11, 2008 at 8:58 PM / IP Logged
Thank you for the help and the diagram.
Mike
