Trailer light wiring.
austinjasonxxx
Member - Posts: 7
Posted: November 09, 2017 at 1:16 PM / IP Logged Link to Post Post Reply Quote austinjasonxxx
I used the wire in a seven pole trailer plug that normally controls the running lights to power after market hazard lights on the trailer. There’s a separate toggle switch for the hazard lights and the running lights. When you turn on the running lights the hazard lights come on.
Is it possible to wire a relay so that when the running lights are on the hazards or not but could be if the hazard lights switch was switched on but normally the hazards would be off.
Friday, May 31, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
