Power Mirror Wiring
lambeau40
Posted: October 08, 2022 at 10:49 PM / IP Logged Link to Post Post Reply Quote lambeau40
Ok, so I have a custom application where I'm trying to wire up some power mirrors. The mirrors are from an early 80's Camaro and have 4 wires. 2 for up/down and 2 for left/right. The switch I am using is from a Pontiac G8 and only has 2 wires. If I check voltage on 1 of the wires I get 12 volts when I press up or right. And the other has 12 volts when I press down or left. Is there any way to wire this with relays or diodes to make it work with these mirrors? Any help would be greatly appreciated!!!
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
