What Is This Relay Configuration Called?
davep.
Gold - Posts: 643
Posted: April 25, 2023 at 10:44 PM / IP Logged Link to Post Post Reply Quote davep.
I saw this relay tonight while going through pics of one of my projects. Kind of a 'different' contact configuration. It's sort of a DPDT, but one of the outputs is connected to either pole. What is this configuration officially called? Thanks.
ADD: I looked at the schematic for its usage in the car. Terminal #5 is not used. Terminals #3 and #4 are N.C., and terminals #1 and #6 are N.O. When the relay changes states, the pairs change states. One pole 'breaks', and the other pole 'makes'.
What Is This Relay Configuration Called? -- posted image.
veiloctane
Member - Posts: 40
Posted: September 13, 2023 at 12:49 AM / IP Logged Link to Post Post Reply Quote veiloctane
known as a double pole double throw DPDT Relay
Relay usually has 6 pins
https://www.electroschematics.com/dpdt-switch-relay/
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
