Wiper On and Headlights
bshow
Posted: August 15, 2005 at 1:08 PM / IP Logged
CA has a new law that requires the headlights to be on anytime the windshield wipers are on (basically). I would like to have the headlights come on automatically when I turn on the wipers. I have figured out a way to do this using 4 spst relays. Three relays would switch 12 volts to a fourth relay which would turn on the low beam lights. These three relays can be low current capicity since they will only be driving the coil of the headlight relay. The coils of the 3 relays would be energized by supplying 12 volts through the high speed wiper switch, 12 volts through the low speed wiper switch, and ground through the intermittent wiper switch. My question is: Can anyone recommend something for a cleaner install than using the 3 low current relays? I will use a Bosch type 40 amp relay for the headlights.
firstclassohio
Member - Posts: 37
Posted: August 16, 2005 at 12:08 PM / IP Logged
wiper switch to 85 on relay
30 to low beam
87 to fused 12 volts or ground depending on low beam voltage you need the same
86 to ground or 12 volts depending on wiper voltage you need opposite
under promise and overdeliver
Wednesday, February 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
