relay not activating
thatsjeek
Posted: September 09, 2005 at 3:46 PM / IP Logged
I recently installed a trunk release to an existing unit that has a channel for a trunk release.
when the car is off the negative output only reads 7 volts or so and the relay wont activate therefore the trunk solenoid doesnt work.
when the car is on the output reads 13 volts and the relay activates and everything works as intended.
i just can't figure out what to do.. any suggestions?
hotwaterwizard
Silver - Posts: 1,350
Posted: September 09, 2005 at 11:13 PM / IP Logged
Find another source of Power for the installed Unit. Find a source that reads 12v when the key is off. Maybe even try running the power lead to the battery.
Also look for a bad Ground.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
blazeronspokes
Copper - Posts: 102
Posted: September 14, 2005 at 8:34 PM / IP Logged
what kind of car is this in?
thatsjeek
Posted: September 15, 2005 at 10:20 AM / IP Logged
95 toyota corolla
blazeronspokes
Copper - Posts: 102
Posted: September 16, 2005 at 9:44 AM / IP Logged
is it the negative output on the alarm brain reading 7 volts? what i would suggest is that you wire a relay with a good power and ground source to give the trunk pop the power it needs.
rami_1r
Member - Posts: 34
Posted: September 24, 2005 at 7:44 AM / IP Logged
i would suggest to replace the vehicles battery.
Wednesday, February 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
