linear actuator for lambo doors
djrob_1
Member - Posts: 6
Posted: August 11, 2007 at 12:35 PM / IP Logged
HI I am installing lambo doors on a 99 lincoln towncar and hooking them up to a linear actuator. I want to run them up and down off one channel in my alarm. I have been through every actuator forum and couldn't find what I was looking for that might be because it cant be done.
Ok the actuator has 2 wires red and black hook power to red and ground to black and it will extend. switch it with power to black and ground to red and it will retract. Is there anyway to hook this up to one channel in my remote (for only one side I will hook the other side to another channel) WITHOUT using micro switches. for example i press lock channel once and the door goes up until the built in limit swich stops it then i press the lock button again and the door closes. If its not possible I understand but if it is this is the best place to find out.
Thanks Dallas
Platinum - Posts: 13,726
Posted: August 11, 2007 at 6:29 PM / IP Logged
linear actuator for lambo doors -- posted image. Latched On/Off Output Using a Single Momentary Pulse
Similar to the momentary to constant configuration above, we can engage and disengage the latched output with a single pulse from a switch or an output from an alarm or remote keyless entry. The first pulse from the switch will engage the latch. The next pulse from the switch will disengage the latch.
Here is a diagram for the latching portion of what you need.  The pushbutton switch at bottom of the picture can be replaced by the negative output of your alarm.
This will take 2 more relays to complete what you need to do. I am looking for a diagram here.  If I can't find one I will write instructions.
Are you sure there are limit switches in the actuators?
Posted: August 11, 2007 at 6:45 PM / IP Logged
No luck finding a suitable diagram so here it goes.   Like I said earlier you will need 2 more relays besides the 4 above.
connect the output from the 4 relays above to terminal 85 of both relays.  Connect ground to terminal 86 of both relays.  Connect the red wire of the actuator to terminal 30 of relay 1.  Connect the black wire of the actuator to term. 30 of relay 2. On relay 1 connect 12 volts to 87A and ground to 87.   On relay 2 connect  Ground to 87A and 12 volts to 87.
We want the setup to pull no current when the doors are closed. In order to test this, disconnect the 12 volt output from the 4 relay setup, if the doors stay down everything is OK.  If the doors go up, you will need to switch the red and black going to the actuators.
If you do not check the above, and have it wrong the relays will be pulling current when the car is parked.  And a dead battery could keep you from getting into the vehicle.
djrob_1
Member - Posts: 6
Posted: August 12, 2007 at 1:13 AM / IP Logged
Thanks Very Much and yes there is limit switches is them
hotwaterwizard
Silver - Posts: 1,350
Posted: August 12, 2007 at 6:28 PM / IP Logged
Most Remotes use a different output for each mode. Mode 1 being the first click of the button and Mode 2 being the second. Just hook the respective outputs to each relay and only two relays are needed to do the job.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
hotwaterwizard
Posted: August 12, 2007 at 6:41 PM / IP Logged
It sure would help to know what Alarm system you have Type and model number.
Stockton California
tuckin-22
Posted: August 16, 2007 at 1:18 PM / IP Logged
what is the m for in the middle
thanks
hotwaterwizard
Posted: August 16, 2007 at 7:40 PM / IP Logged
M = Motor or Actuator Motor
Stockton California
hotwaterwizard
Posted: August 16, 2007 at 7:46 PM / IP Logged
Stockton California
djrob_1
Member - Posts: 6
Posted: August 16, 2007 at 7:51 PM / IP Logged
its an autoloc alarm 8 channel I dont know the model number though
Page of 3
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
