park light goes off when you open door
demented
Member - Posts: 6
Posted: August 21, 2007 at 12:18 PM / IP Logged
I want to hook up a relay system that turns my park lights off when I open my door after I forgot them on. Any help on a diagram/suggestion.
hotwaterwizard
Silver - Posts: 1,350
Posted: August 21, 2007 at 10:49 PM / IP Logged
You need to latch the lights and unlatch them with the pin switch. It would be easier if you use a seperate Alarm switch for this purpose. park light goes off when you open door -- posted image.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
demented
Member - Posts: 6
Posted: August 23, 2007 at 12:42 PM / IP Logged
^^^ That will not work in my application. sorry
I was thinking more like, when the ignition is it will power a relay to supply the light switch (latched)
So the lights can be turned on and off using the light switch once the ignition came on and latched. But if I foret my lights on, when i switch off my ignition, the lights will still be on...and only go off after I open my door. Also, if the car is running and I open my door, the lights should remain on if they are on.
dualsport
Silver - Posts: 983
Posted: August 23, 2007 at 9:19 PM / IP Logged
It'd be easy to do with a digital logic gate to control your relay, if you can't find a relay only solution. Depends how comfortable you are with a bit of electronics work, but it's pretty simple if you've done any. A CD4011 chip. a BS170 transistor, a sprinkling of diodes, and your relay is all it would need.
hotwaterwizard
Posted: August 23, 2007 at 10:07 PM / IP Logged
Here is the same circuit modifiedpark light goes off when you open door -- posted image.
Stockton California
dualsport
Silver - Posts: 983
Posted: August 24, 2007 at 1:11 AM / IP Logged
Here's another way to go, assuming the door switch closes to ground when the door is opened.
hotwaterwizard
Posted: August 24, 2007 at 8:16 AM / IP Logged
Just curiousDualsport,
Why use a Static sensitive MOSFET when a Transistor will do the job without having to use wrist ground straps and a shielded soldering iron durring assembly.
Back in the day before Digital Voice Recorders and all that stuff I used a Cassete player with a Tape from an answering machine to verbaly remind me when I left the lights on in my own voice. When I opened the door it used a relay to power the cassete. I would only come on when the lights were on and the door opened.
Stockton California
hotwaterwizard
Posted: August 24, 2007 at 8:31 AM / IP Logged
This circuit could be used a relay AND Circuit.
Stockton California
dualsport
Silver - Posts: 983
Posted: August 24, 2007 at 8:54 AM / IP Logged
A regular transistor can be used with no problem here; I just like the BS170 in general because it operates on voltage rather than current, so the input impedance can be ignored when using it in timing circuits, and no concern about proper biasing.
The logic gate draws negligible power when on standby, which is what you'd want for something that can operate with the ignition turned off. If someone isn't comfortable working with electronics, then a relays-only setup would be good. Otherwise, a single extra relay costs more than all the electronic components this would need.
dualsport
Silver - Posts: 983
Posted: August 24, 2007 at 9:00 AM / IP Logged
Lot of cars go bong bong bong when the lights are left on when exiting the car.
I'd consider using a piezoelectric buzzer hooked up under the hood to the parking lights and ignition power, so that whenever the lights are on with the ignition off, it'll sound off (polarity sensitive so it doesn't come on with ignition on and lights off).
As you walk away from the car, you'll hear it. No problems with possibly failing relays, and it'll alert you to turn things off. That'd be a $2.99 solution using a buzzer and a diode.
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
