latching relay with input
rsottawa
Member - Posts: 6
Posted: September 19, 2007 at 7:45 PM / IP Logged
Hi All,
Is there such a thing as a latching relay with a (-) input (i.e alarm arm/disarm). I want to break continuality on a wire when the alarm is armed and connect when disarmed.
Thanks!
missionarymike
Posted: September 20, 2007 at 12:53 PM / IP Logged
Yes, i have used a model by Altronix RBR1224.  this can use a + or - momentary pulse to latch and unlatch.
hotwaterwizard
Silver - Posts: 1,350
Posted: September 21, 2007 at 1:02 AM / IP Logged
latching relay with input -- posted image.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
hotwaterwizard
Posted: September 21, 2007 at 1:16 AM / IP Logged
By adding another relay you can get the requested Results.
Stockton California
rsottawa
Member - Posts: 6
Posted: October 16, 2007 at 4:37 PM / IP Logged
Will this 3 relay setup drain the battery in either latched or unlatched state?
rsottawa
hotwaterwizard
Posted: October 16, 2007 at 8:49 PM / IP Logged
As it sits in the unlatched state it will not drain the battery It only does when a pulse is applied and the output is latched.
Stockton California
dualsport
Silver - Posts: 983
Posted: November 09, 2007 at 1:06 AM / IP Logged
You can use what's called a bistable relay to switch it on or off without a constant power draw in either state; they just need a single pulse to change positions.
They're pricier than regular monostable relays though, so depending on what you're looking to switch, you might be better off just using a transistor to turn your device on and off. Solid state devices won't draw power like relays do, and you can get them to handle pretty large currents.
hotwaterwizard
Posted: November 09, 2007 at 8:44 AM / IP Logged
Stockton California
rsottawa
Member - Posts: 6
Posted: November 09, 2007 at 2:22 PM / IP Logged
I ended up finding a 12v latching relay. Turns out 70's era VW's used a latching relay to control the head light hi/low beams. VW part number is 111-941-583. I have heard some people say the quality is not too good (made in Brasil) but so far so good.
rsottawa
Wednesday, May 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
