2004 hyundai accent gs, remote start wiring
Welcome Guest :)
drw7000
Member -
Posted: February 13, 2008 at 11:04 PM / IP Logged
Hi,
I'm Looking for a remote start wiring diagram for a 2004 Hyundai Accent GS (Canadian model). Also, does this require an immobilizer bypass kit? Thanks for your time.
caraudio904
Copper -
Posted: March 01, 2008 at 8:10 PM / IP Logged
The 556UW is the listed bypass for that car, the only one needing a bypass are the canadian models so yea make sure u get it (556UW)
MODEL | YEAR(S) |
ACCENT | 2003 -2005 |
KEY | T-HARNESS | IMMOBILIZER |
N/A | N/A | See NOTE *4 |
PART | COLOR | LOCATION |
12 VOLT CONSTANT | RED (+) | IGNITION SWITCH HARNESS |
STARTER | WHITE (+) | IGNITION SWITCH HARNESS |
STARTER 2 | N/A | |
IGNITION 1 | GREEN (+) | IGNITION SWITCH HARNESS |
IGNITION 2 | N/A | |
IGNITION 3 | N/A | |
ACCESSORY /HEATER BLOWER 1 | YELLOW (+) | IGNITION SWITCH HARNESS |
ACCESSORY /HEATER BLOWER 2 | BLUE (+) | IGNITION SWITCH HARNESS |
KEYSENSE | N/A | |
PARKING LIGHTS ( - ) | GREEN (-) or RED / BLACK (-) | @ HEADLIGHT SWITCH |
PARKING LIGHTS ( + ) | GREEN/ ORANGE (+) and GREEN/ BLACK (+) Use both, See NOTE *3 | IN DRIVERS KICK PANEL, HARNESS to REAR of VEHICLE |
POWER LOCK | YELLOW (TYPE B) | @ TACM, 12-Pin Plug, See NOTE *1 |
POWER UNLOCK | BLUE (TYPE B) | @ TACM, 12-Pin Plug, See NOTE *1 |
DOOR TRIGGER | GREEN (-) | IN DRIVER KICK PANEL or at INSTRUMENT CLUSTER |
DOMELIGHT SUPERVISION | USE DOOR TRIGGER, Requires Part #775 Relay | |
TRUNK RELEASE | N/A | |
SLIDING POWER DOOR | N/A | |
HORN | BLUE/ORANGE (-) | @ STEERING COLUMN HARNESS |
TACH | GRAY | @ ECM, UNDER DRIVERS DASH, PIN 8 |
WAIT TO START LIGHT | N/A | |
BRAKE | PINK/BLACK (+) | @ SWITCH ABOVE BRAKE PEDAL |
FACTORY ALARM DISARM | N/A | |
ANTI-THEFT | N/A | |
EXTRA INFORMATION |
NOTE *1 the TACM (Time Alarm Control Module) is located to the LEFT of the STEERING COLUMN NOTE *2 the PASSENGER COMPARTMENT RELAY BOX is located behind the TACM Module. NOTE *3 this vehicle has 2 PARRKING LIGHT wires, that will require 2 extra relays part #775, to connect, See DIAGRAM NOTE *4 the CANADIAN Model of this Vehicle, may have a TRANSPONDER ANTI-THEFT System that will require an extra Programmed Ignition Key and a 791 Security Bypass Module for Remote Starting. |
Southern Stylez
Jacksonville, FL 32218
Saturday, June 8, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
