1991 acura legend coupe ls
tlangevain
Posted: June 11, 2009 at 2:47 AM / IP Logged
need a diagram of how to hookup the metal bars etc in drivers door,  and what the vss looks like where it is located and how to disassemble it as well as the speedometer sensor, and color wire diagram for the cig lighter is it okay to purchase a used vss or get one out of a car at pick a part they are too expensive for me right now  1991 acura legend coupe ls
tameelangevain
Posted: June 11, 2009 at 3:17 AM / IP Logged
What do you mean by metal bars? The best place to pick up the VSS would be one of the leads to the speedo, incidentally VSS =speed sensor. Cig lighter wiring colours? Too basic to even answer!  Acc (WHITE/ blue or RED / yellow) at 15amps to centre, black or white /black ground to outer and green with a secondary as illumination, and I've never even looked!
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
