Item Wire Color Wire Polarity Wire Location
12volts wht/red (15A), blk/red (7.5A) + ignition harness
Starter BLACK/ white + ignition harness
Second Starter N/A
Ignition BLACK/ red + ignition harness
Second Ignition blue/black + ignition harness
Third Ignition N/A
Accessory black + ignition harness
Second Accessory N/A
Keysense RED / black - ignition harness
Note:Using the status output to trigger this wire during remote start will disarm the factory alarm without unlocking the doors.
Power Lock blue/white - driver fuse box, bottom, 42 pin plug
Note:Meter this wire while turning the key in the passenger door or rear hatch key cylinder. The driver door key cylinder lock wire is blue/white (-) at the driver door ECU in the door.
Power Unlock GREEN/ black - driver fuse box, bottom, 42 pin plug
Note:Meter this wire while turning the key in the passenger door or rear hatch key cylinder. The driver door key cylinder unlock wire is GREEN/ black (-, double pulse) at the driver door ECU in the door.
Lock Motor purple 5wi driver fuse box, bottom, 11 pin plug
Unlock Motor blue/black 5wi Body ECU, 30 pin plug, pin 10
Note:The Body ECU is attached to the back of the fuse box in the driver kick panel.
Disarm Defeat blue/black 5wi driver fuse box, L side, 12 pin plug
Parking Lights + green + Body ECU, 30 pin plug, pin 28
Parking Lights - GREEN/ black - sw. or Body ECU, 26 pin plug, pin 8
Hazards white - turn signal flasher near column
Turn signal (L) GREEN/ black + turn signal flasher near column
Turn signal (R) GREEN/ YELLOW + turn signal flasher near column
Head Light RED / white - sw. or Body ECU, 26 pin plug, pin 1
Reverse Light RED / black + driver fuse box, bottom, 42 pin plug
Door Trigger see notes - Body ECU, 24 pin plug
Note:The LF door is RED / yellow in pin 23, RF door is RED / black in pin 24, LR door is RED / blue in pin 11, and RR door is RED / green in pin 12. Use all four wires and diode isolate each. The Body ECU is attached to the back of the fuse box in the driver kick panel.
Dome supervision GREEN / WHITE - driver fuse box, top L, 20 pin plug
Trunk/Hatch Pin RED / blue - Body ECU, 24 pin plug, pin 7
Hood Pin blue/black - pass. fuse box, top, 25 pin plug
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer black ac data link conn. under driver dash
Wait to start N/A
Speed Sense purple amplifier under passenger seat
Brake Wire GREEN / WHITE + brake pedal switch
Parking Brake RED / white - driver fuse box, bottom, 42 pin plug
Horn Trigger GREEN/ orange - driver fuse box, top, 25 pin plug
Wipers blue/black (L), blue/red (H) + windshield wiper switch
LF Window up/down yellow - green A LF window switch in door
Note:Extended triggers on the driver door key cylinder lock/unlock wires will roll the windows up/down. Use validity channels to control.
RF Window up/down yellow - green A RF window switch in door
LR Window up/down yellow - green A LR window switch in door
RR Window up/down yellow - green A RR window switch in door
Sun Roof open/close motor part of module
Sun Roof limit N/A
Memory Seat 1 blue - Body ECU, 30 pin plug, pin 20
Memory Seat 2 yellow - Body ECU, 30 pin plug, pin 2
Memory Seat 3 N/A
Radio 12v blue / YELLOW + radio harness
Radio Ground brown - radio harness
Radio Ignition gray + radio harness
Radio Illumination green + radio harness
Factory Amp Turn-on N/A
Power Antenna BLACK/ red + radio harness
LF Speaker +/- pink - purple +,- amplifier under passenger seat
RF Speaker +/- lt. green - blue +,- amplifier under passenger seat
LR Speaker +/- black - yellow +,- amplifier under passenger seat
RR Speaker +/- red - white +,- amplifier under passenger seat
