2007 kia spectra 5 remote start info
stereocreature
Posted: January 16, 2010 at 1:22 PM / IP Logged
Hello all,  does anyone have any remote start info for a 2007 Kia Spectra 5 (manual)?
Thanks,
Jon
lectricguy
Copper - Posts: 359
Posted: January 17, 2010 at 6:53 PM / IP Logged
2007 kia spectra 5 remote start info -- posted image.
BatteryPINK & WHITE(+)IGNITION SWITCH HARNESS2007 kia spectra 5 remote start info -- posted image.
2007 kia spectra 5 remote start info -- posted image.Ignition 1ORANGE(+)IGNITION SWITCH HARNESS
2007 kia spectra 5 remote start info -- posted image.Accessory 1YELLOW(+)IGNITION SWITCH HARNESS
2007 kia spectra 5 remote start info -- posted image.Accessory 2BLUE(+)IGNITION SWITCH HARNESS
2007 kia spectra 5 remote start info -- posted image.Starter 1RED(+)IGNITION SWITCH HARNESS
2007 kia spectra 5 remote start info -- posted image.Anti-Theft TypeUNIVERSAL IMMOBILIZER
2007 kia spectra 5 remote start info -- posted image.Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
2007 kia spectra 5 remote start info -- posted image.Key SenseORANGE(+)IGNITION SWITCH HARNESS
2007 kia spectra 5 remote start info -- posted image.TachometerYELLOW(AC)AT IGNITION COIL
2007 kia spectra 5 remote start info -- posted image.Speed SenseGREEN/ ORANGE(AC)AT THE BACK OF THE INSTRUMENT CLUSTER 24 PIN CONNECTOR PIN 13
2007 kia spectra 5 remote start info -- posted image.Parking LightsGREEN(-)AT VEHICLE LIGHT SWITCH
2007 kia spectra 5 remote start info -- posted image.Brake LightsRED / BLACK(+)AT SWITCH ABOVE BRAKE PEDAL
2007 kia spectra 5 remote start info -- posted image.Reverse LightsRED / ORANGE(+)IN HARNESS IN DRIVER KICKPANEL TO REAR
2007 kia spectra 5 remote start info -- posted image.HornBLUE/BLACK(-)IN HARNESS AT STEERING COLUMN
2007 kia spectra 5 remote start info -- posted image.All Door TriggerGRAY(-)IN HARNESS TO GAUGES
2007 kia spectra 5 remote start info -- posted image.Domelight SuperBLUE/BLACK(-)IN HARNESS IN DRIVER KICKPANEL
2007 kia spectra 5 remote start info -- posted image.LF LatchGREEN/ BLACK(-)AT VEHICLE FUSEBOX
2007 kia spectra 5 remote start info -- posted image.RF LatchGREEN/ BLACK(-)AT VEHICLE FUSEBOX
2007 kia spectra 5 remote start info -- posted image.LR LatchGREEN/ BLACK(-)AT VEHICLE FUSEBOX2007 kia spectra 5 remote start info -- posted image.
2007 kia spectra 5 remote start info -- posted image.Trunk TriggerGREEN(-)IN HARNESS IN DRIVERS KICKPANEL
2007 kia spectra 5 remote start info -- posted image.Hood TriggerGREEN(-)AT VEHICLE HOOD PIN SWITCH
2007 kia spectra 5 remote start info -- posted image.Parking BrakeWHITE(-)AT VEHICLE PARKING BRAKE SWITCH
2007 kia spectra 5 remote start info -- posted image.Trnk ReleaseBROWN(-)AT RELEASE SWITCH
2007 kia spectra 5 remote start info -- posted image.Power UnlockYELLOW/BLACK(-)IN HARNESS IN DRIVER KICKPANLE TO DOOR
2007 kia spectra 5 remote start info -- posted image.PowerLockYELLOW/ORANGE(-)IN HARNESS IN DRIVER KICKPANEL TO DOOR
2007 kia spectra 5 remote start info -- posted image.Driver Mtr UnlockGREEN(REV)IN HARNESS IN DRIVER KICKPANEL TO DOOR
2007 kia spectra 5 remote start info -- posted image.Driver Mtr LockPINK(REV)IN HARNESS IN DRIVER KICKPANEL TO DOOR
2007 kia spectra 5 remote start info -- posted image.LF Window UpORANGE(REV)AT MASTER WINDOW CONTROL SWITCH
2007 kia spectra 5 remote start info -- posted image.LF Window DnYELLOW/WHITE(REV)AT MASTER WINDOW CONTROL SWITCH
2007 kia spectra 5 remote start info -- posted image.RF Window UpGREEN(REV)AT MASTER WINDOW CONTROL SWITCH
2007 kia spectra 5 remote start info -- posted image.RF Window DnBLUE(REV)AT MASTER WINDOW CONTROL SWITCH
2007 kia spectra 5 remote start info -- posted image.LR Window UpYELLOW/BLUE(REV)AT MASTER WINDOW CONTROL SWITCH
2007 kia spectra 5 remote start info -- posted image.LR Window DnWHITE/ BLUE(REV)AT MASTER WINDOW CONTROL SWITCH
2007 kia spectra 5 remote start info -- posted image.RR Window UpBROWN(REV)AT MASTER WINDOW CONTROL SWITCH
2007 kia spectra 5 remote start info -- posted image.RR Window DnRED(REV)AT MASTER WINDOW CONTROL SWITCH
NOTES:
Battery Pink & White are both fused at 30 Amps.
LR Latch GREEN/ Black is common to both rear doors.
Lectric Guy
stereocreature
Posted: January 19, 2010 at 11:41 AM / IP Logged
Thanks, much appreciated
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
