2011 Ford Explorer XLT Alarm/Remote Start/Stereo Wiring
ssrad750
Posted: January 27, 2011 at 9:02 PM / IP Logged
Does any body have a remote start  wiring diagram for a 2011 Ford explorer XLT?
monty_77
Copper - Posts: 491
Posted: January 28, 2011 at 12:40 AM / IP Logged
Item     Wire Color     Polarity     Wire Location
12 Volts     GREEN/ red (15A)     +     ignition sw, blk 7 pin plug, pin 4 or start/stop sw, blk 6 pin plug, pin 4
Second 12 Volts     yellow/orange (30A)     +     trailer brake pre-wiring, gray 6 pin plug, pin 1
     The trailer brake pre-wiring is behind the hood release.
Starter     blue/white (without Intelligent Access)     +     ignition switch, black 7 pin plug, pin 7
Second Starter     blue/white (with Intelligent Access)      +     start/stop switch, black 6 pin plug, pin 1
Ignition     WHITE/ orange     +     ignition switch, black 7 pin plug, pin 1
     On vehicles with Intelligent Access, use PURPLE / orange (+) (for ignition sense only) at the BCM, gray 10 pin plug (E), pin 10. The BCM (Body Control Module) is the dash fuse box, under the driver dash.
Second Ignition     N/A
Third Ignition     N/A
Accessory     PURPLE / green     +     ignition switch, black 7 pin plug, pin 6
Second Accessory     N/A
Third Accessory     N/A
Keysense     blue/gray (without Intelligent Access)     + ignition switch, black 7 pin plug, pin 5
Data Bus     yel/org (TX), pur/red (RX)(w/o Intelligent Access)     data     PATS Transceiver, black 4 pin plug, pins 3 and 4
     The PATS (Passive Anti-Theft System) Transceiver is around the ignition switch. The PATS ignition is PURPLE / orange in pin 1, and ground is BLACK/ blue in pin 2.
Can Bus High     gray/orange (MS CAN); WHITE/ blue (HS CAN)     data     data link connector, black 16 pin plug, pins 3 and 6
Can Bus Low     PURPLE / orange (MS CAN); white (HS CAN)     data     data link connector, black 16 pin plug, pins 11 and 14
Can Bus Sw     N/A
Power Lock     blue/green     -     driver kick or BCM, black 26 pin plug (C), pin 6
Power Unlock     yellow/purple     -     driver kick or BCM, black 26 pin plug (C), pin 8
Lock Motor     gray/brown     5 wire     driver kick, door harness
Driver Unlock Motor     blue/green     5 wire     driver kick, door harness
Passenger Unlock Motor     PURPLE / gray     5 wire     driver kick, harness to rear
Parking Lights (-)     (HS CAN)
Parking Lights (+)     yellow/blue     +     BCM, gray 10 pin plug (E), pin 6
Hazards     BROWN / yellow     -     BCM, black 52 pin plug (B), pin 32
Turn Signal (Left)     blue/green (F); gray/blue (R)     +     BCM, brown 26 pin plug (F), pin 8; black 26 pin plug (C), pin 14
Turn Signal (Right)     yellow/purple (F); BROWN / white (R)     +     BCM, brown 26 pin plug (F), pin 7; black 26 pin plug (C), pin 15
Headlight     BROWN / blue (L); blue/green (R)     +     BCM, gray 10 pin plug (E), pins 2 and 1
AutoLights
Reverse Light     blue/white     +     driver kick or BCM, black 32 pin plug (D), pin 13
Left Front Door Trigger     GREEN/ purple     - N.C.     driver kick or BCM, black 26 pin plug (C), pin 9
Right Front Door Trigger     white     - N.C.     driver kick or BCM, black 26 pin plug (C), pin 5
Left Rear Door Trigger     green     - N.C.     driver kick or BCM, black 26 pin plug (C), pin 20
Right Rear Door Trigger     yellow     - N.C.     driver kick or BCM, black 26 pin plug (C), pin 21
Dome Supervision     gray/purple (dome lamp); purple (puddle lamp)     +     BCM, gray 12 pin plug (A), pin 1; black 26 pin plug (C), pin 1
Trunk/Hatch Pin     gray/orange     - N.C.     driver kick or BCM, black 26 pin plug (C), pin 19
Rear Glass Pin     N/A
Hood Pin     blue/orange     - N.C.     BCM, brown 26 pin plug (F), pin 2
Trunk/Hatch Release     brown (rear handle switch)     -     driver kick or BCM, black 26 pin plug (C), pin 23
     The BCM (Body Control Module) is the dash fuse box, under the driver dash. On vehicles with power liftgate, the open/close wire is gray / YELLOW (-) at the power liftgate release switch, black 8 pin plug, pin 7.
Trunk Release Motor     GREEN/ brown     5 wire     driver kick, harness to rear
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     arms on lock with door open
Factory Alarm Disarm     factory remote only (To disarm with out the factory remote pulse the Ignition and the Bypass at the same time)
Disarm No Unlock     Transponder and ignition
Trunk Alarm Shunt     N/A
Tachometer     grn/blu, gry/yel, pur/gry, yel/org, brn, or grn/wh     ac     any fuel injector, 2 pin plug, pin 1
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     N/A
Fuel Pump     PURPLE / green     +     driver kick, harness to rear
Rear Defroster     WHITE/ orange     - latched     junction connector below BCM, white 59 pin plug, pin 14
Mirror Defroster     same as rear defroster
Left Front Heated Seat     (MS CAN)
Right Front Heated Seat     (MS CAN)
Speed Sense     yellow/orange     ac     Powertrain Control Module, black 50 pin plug, pin 25
     The Powertrain Control Module is in the engine compartment, on the passenger firewall.
Brake Wire     blue/orange     +     trailer brake pre-wiring, gray 6 pin plug, pin 2
Parking Brake     WHITE/ purple     -     parking brake switch or BCM, black 26 pin plug (C), pin 7
Horn Trigger     PURPLE / green     -     horn switch or BCM, black 52 pin plug (B), pin 33
Wipers     (LIN bus)
Left Front Window (Up/Down)     blue/gray - yellow/purple (base models only)     A     master window switch, 4 pin plug, pins 4 and 2
Right Front Window (Up/Down)     WHITE/ orange - purple (base models only)     A     passenger window switch, 8 pin plug, pins 4 and 8
Left Rear Window (Up/Down)     GREEN/ purple - brown     A     left rear window switch, 8 pin plug, pins 4 and 8
Right Rear Window (Up/Down)     WHITE/ purple - gray     A     right rear window switch, 8 pin plug, pins 4 and 8
Sun Roof (Open/Close)     pur/wht - pur/brn (function with ignition on only)     -     sun roof switch, gray 12 pin plug, pins 6 and 8
Sun Roof (Limit/Close)     N/A
Memory Seat 1     PURPLE / red     -     driver kick, door harness
Memory Seat 2     yellow     -     driver kick, door harness
Memory Seat 3     gray/purple     -     driver kick, door harness
Radio 12V     gray/red     +     radio, 24 pin plug, pin 1
Radio Ground     BLACK/ blue     -     radio, 24 pin plug, pin 13
Radio Ignition     (Infotainment CAN)
Radio Illumination     (Infotainment CAN)
Factory Amp Turn-on     PURPLE / red     +     radio, black 26 pin plug, pin 18
Power Antenna     blue     +     radio, 24 pin plug, pin 2
Left Front Speaker (+/-)     white - WHITE/ brown or GREEN/ orange - gray/orange     +,-     radio, 24 pin plug, pins 22 and 10
     The preamp output wires are green - gray at the radio, 24 pin plug, pins 20 and 8 (Premium Plus Audio), or 24 pin plug, pins 22 and 10 (Sony Sound). If equipped, the amplifier is in the right rear quarter panel. On vehicles with amplifier, the speaker wires are white - WHITE/ brown at the amplifier, black 8 pin plug, pins 1 and 2 (Premium Plus Audio), or 16 pin plug, pins 2 and 10 (Sony Sound). The tweeter wires are GREEN/ orange - gray/orange at the amplifier, 16 pin plug, pins 3 and 11 (Sony Sound).
Right Front Speaker (+/-)     WHITE/ purple - WHITE/ orange or PURPLE / org - yel/og     +,-     radio, 24 pin plug, pins 23 and 11
     The preamp output wires are purple - yellow at the radio, black 26 pin plug, pins 4 and 17 (Premium Plus Audio), or 24 pin plug, pins 23 and 11 (Sony Sound). If equipped, the amplifier is in the right rear quarter panel. On vehicles with amplifier, the speaker wires are WHITE/ purple - WHITE/ orange at the amplifier, black 8 pin plug, pins 3 and 4 (Premium Plus Audio), or 16 pin plug, pins 6 and 14 (Sony Sound). The tweeter wires are PURPLE / orange - yellow/orange at the amplifier, 16 pin plug, pins 7 and 15 (Sony Sound).
Left Rear Speaker (+/-)     WHITE/ green - BROWN / yellow     +,-     radio, 24 pin plug, pins 21 and 9
     If equipped, the amplifier is in the right rear quarter panel. On vehicles with amplifier, the speaker wires are WHITE/ green - BROWN / yellow at the amplifier, 16 pin plug, pins 4 and 12 (Sony Sound). The tweeter wires are GREEN/ brown - gray/brown at the amplifier, 16 pin plug, pins 5 and 13 (Sony Sound).
Right Rear Speaker (+/-)     BROWN / white - BROWN / blue     +,-     radio, 24 pin plug, pins 24 and 12
     If equipped, the amplifier is in the right rear quarter panel. On vehicles with amplifier, the speaker wires are BROWN / white - BROWN / blue at the amplifier, 16 pin plug, pins 8 and 16 (Sony Sound). The tweeter wires are GREEN/ brown - gray/brown at the amplifier, 16 pin plug, pins 5 and 13 (Sony Sound).
Center Channel (+/-)     green - gray / YELLOW (Sony Sound)     +,-     amplifier, 16 pin plug, pins 1 and 9
Subwoofer (+/-)     GREEN/ pur - gry (1); purple - yel (2) (Sony Sound)     +,-     amplifier, gray 16 pin plug, pins 1 and 9; 2 and 10
Aux. Audio Input Left (+/-)     blue - WHITE/ green (without SYNC)     +,-     radio, 24 pin plug, pins 17 and 6
     On vehicles with SYNC, they are blue - YELLOW /GREEN at the APIM, black 54 pin plug, pins 10 and 11. The APIM (Accessory Protocol Interface Module) is in the center of the dash, connected to the display.
Aux. Audio Input Right (+/-)     blue/green - WHITE/ green (without SYNC)     +,-     radio, 24 pin plug, pins 18 and 6
     On vehicles with SYNC, they are blue/green - WHITE/ green at the APIM, black 54 pin plug, pins 28 and 29. The APIM (Accessory Protocol Interface Module) is in the center of the dash, connected to the display.
RSE Video (+/-)     wht/grn - brn/pur (camera); blu/wh - grn/blu (aux)     +,-     APIM, black 54 pin plug, pins 14 and 15; 34 and 35
RSE Audio Left (+/-)     blue - gray/orange (SYNC audio)     +,-     radio, black 26 pin plug, pins 12 and 25
RSE Audio Right (+/-)     PURPLE / green - BROWN / white (SYNC audio)     +,-     radio, black 26 pin plug, pins 13 and 26
Satellite Radio 12 Volts     N/A
Satellite Radio Ground     N/A
Satellite Radio Ignition     N/A
Satellite Radio Antenna     N/A
Satellite Audio Left (+/-)     N/A
Satellite Audio Right (+/-)     N/A
Item     Size     Depth     Location
Headunit     irregular          center of dash
Left Front Speaker     6 x 8          left front door
Left Front Tweeter               left front door
Right Front Speaker     6 x 8          right front door
Right Front Tweeter               right front door
Left Rear Speaker     6.5          left rear door
Left Rear Tweeter               left rear quarter panel or rear pillar
Right Rear Speaker     6.5          right rear door
Right Rear Tweeter               right rear quarter panel or
rear pillar
Center Channel               top center of dash
Subwoofer               right rear quarter panel
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner     (built into radio)
Twelvoltz
Platinum - Posts: 2,384
Posted: January 28, 2011 at 6:58 AM / IP Logged
That 2011 Explorer uses an 80 bit transponder. If you are doing the installation yourself, you would have to use a key-in-a-box bypass (losing one of the keys in the process)...or you would need to use a programmable bypass that requires not only flash-programming before installation, but also during. Once all connections are made, you start the programming process, remove the bypass and hook it to a computer, then flash-program the bypass to clone (or in Idata's terminology "KLON") the transponder information. Take a look through the installation guide for more information. You can find the guide here.
monty_77
Copper - Posts: 491
Posted: January 28, 2011 at 11:18 AM / IP Logged
Fortin's EVO-RIDE can do the 80bit key with out flashing
but i have yet to see anyone selling them
ssrad750
Posted: February 09, 2011 at 9:10 PM / IP Logged
Thanks for the info on the wiring. I did the customer truck yesterday and it  went good and i use a Evo-ride . I only needed to use three wires for the hook up on the Evo-ride and the wires are on the left side of center console including the power,starter,etc. Just pull on the wires and there is more then plenty to due the job. I flash the unit to 1.3 version and there is no security light on the 2011 ford explorer by the way,so I counted up to 4 to program both of the keys and it work fine. If the truck key has SA on it ,it's a 80 bit transponder. The Fortin Evo-ride does't need to be taking out of the truck once it's been program which took me about 10 sec. or so to program. Jeff at Audio warehouse in Lodi nj has them.
Twelvoltz
Posted: February 09, 2011 at 9:20 PM / IP Logged
Thank you for the update! They had the 80 bit Ford listed as 'preliminary' in their manual when I posted the earlier response. Great to hear that a company has a bypass that doesn't require the extra steps.
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
