2012 Ford Focus Titanium With Sony Stereo Wiring
jersdungeon
Posted: September 24, 2012 at 1:42 PM / IP Logged
Hi I am hoping someone might have a wiring diagram for a 2012 focus titanium that has the Sony stereo and subwoofer. I would like to upgrade it but it is a factory sony/ford amp and has special wiring harness. I really would like to know what wire does what. Any help would be appreciated. Thanks
Jer
tommy...
Gold - Posts: 1,901
Posted: September 24, 2012 at 1:45 PM / IP Logged
http://www.metraonline.com/files/products/INSTFRST-2_web.pdf
2012 Ford Focus (Smart Key)     DirectWire 2.0 Vehicle Information
Audio
Item     Wire Color     Polarity     Wire Location
Radio 12V     BROWN / red     +     radio, black 24 pin plug, pin 1
Radio Ground     black     -     radio, black 24 pin plug, pin 13
Radio Ignition     (Infotainment CAN)
Radio Illumination     brown (without SYNC)     + dimmer     radio controls, 8 pin plug, pin 3
Factory Amp Turn-on     yellow/purple     +     radio, black 26 pin plug, pin 18
Power Antenna     yellow/orange     +     radio, black 24 pin plug, pin 2
Left Front Speaker (+/-)     white - WHITE/ brown     +,-     radio, black 24 pin plug, pins 22 and 10
If equipped, the amplifier is in the left front of the cargo compartment floor. On vehicles with amplifiier, the speaker wires are white - WHITE/ brown at the amplifier, gray 16 pin plug, pins 2 and 10. The tweeter wires are PURPLE / orange - yellow/orange at the amplifier gray 16 pin plug, pins 3 and 11.
Right Front Speaker (+/-)     WHITE/ purple - WHITE/ orange     +,-     radio, black 24 pin plug, pins 23 and 11
If equipped, the amplifier is in the left front of the cargo compartment floor. On vehicles with amplifiier, the speaker wires are WHITE/ purple - WHITE/ orange at the amplifier, gray 16 pin plug, pins 6 and 14. The tweeter wires are GREEN/ orange - gray/orange at the amplifier gray 16 pin plug, pins 7 and 15.
Left Rear Speaker (+/-)     BROWN / green or WHITE/ green - BROWN / yellow     +,-     radio, black 24 pin plug, pins 21 and 9
If equipped, the amplifier is in the left front of the cargo compartment floor. On vehicles with amplifiier, the speaker wires are WHITE/ green - BROWN / yellow at the amplifier, gray 16 pin plug, pins 4 and 12.
Right Rear Speaker (+/-)     BROWN / white - BROWN / blue     +,-     radio, black 24 pin plug, pins 24 and 12
If equipped, the amplifier is in the left front of the cargo compartment floor. On vehicles with amplifiier, the speaker wires are BROWN / white - BROWN / blue at the amplifier, gray 16 pin plug, pins 8 and 16.
Center Channel (+/-)     blue - PURPLE / green     +,-     radio, black 24 pin plug, pins 20 and 8
If equipped, the amplifier is in the left front of the cargo compartment floor. On vehicles with amplifiier, the speaker wires are green - gray / YELLOW at the amplifier, gray 16 pin plug, pins 1 and 9.
Subwoofer (+/-)     purple - yellow (1); GREEN/ purple - gray (2)     +,-     amplifier, blue 16 pin plug, pins 1 and 9; 2 and 10
Aux. Audio Input Left (+/-)     blue/red - (shield) (without SYNC)     +,-     radio, black 24 pin plug, pins 17 and 6
Aux. Audio Input Right (+/-)     BROWN / red - (shield) (without SYNC)     +,-     radio, black 24 pin plug, pins 18 and 6
RSE Video (+/-)     blue - green (rear view camera)     +,-     SYNC Module, black 54 pin plug, pins 14 and 15
The SYNC Module is in the center of the dash, above the radio. The aux. video wires are brown - BROWN / yellow at the SYNC Module, black 54 pin plug, pins 34 and 35.
RSE Audio Left (+/-)     green - gray or blue - gray/orange (SYNC audio)     +,-     radio, black 26 pin plug, pins 12 and 25
RSE Audio Right (+/-)     purple - yellow or pur/grn - brn/wht (SYNC audio)     +,-     radio, black 26 pin plug, pins 13 and 26
Satellite Radio 12 Volts     N/A
Satellite Radio Ground     N/A
Satellite Radio Ignition     N/A
Satellite Radio Antenna     N/A
Satellite Audio Left (+/-)     N/A
Satellite Audio Right (+/-)     N/A
M.E.C.P & First-Class
jersdungeon
Posted: September 24, 2012 at 8:03 PM / IP Logged
Thank you so much, that is exactly what I needed.
Jer
tommy...
Gold - Posts: 1,901
Posted: September 25, 2012 at 9:09 AM / IP Logged
You're Welcome...
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
