2017 Chevrolet Equinox - North America
Item Wire Color Polarity Wire Location
12 Volts Red/White (30A) + BCM under driver dash, blue 27 pin plug, pin 4
Second 12 Volts Red/White (5A only) + Ignition Switch, white 6 pin plug, pin 2
Ground (chassis ground)
Starter Violet (for starter kill only) +
Starter Motor or Underhood Fuse Box, gray 40 pin plug (X1), pin B3
Second Starter Pink (R Code) (see Tech Doc 1605) + 9600 Ignition Switch, white 6 pin plug, pin 4 Ohms
Ignition Pink + Ignition Switch, white 6 pin plug, pin 1
Accessory Brown + Ignition Switch, white 6 pin plug, pin 3
Second Accessory (same as second starter)
+ 6300 Ohms
Keysense (same as second starter)
CAN Bus High Tan/Black Data OBD-Data Link Connector, black 16 pin plug, pin 6
CAN Bus Low Tan Data OBD-Data Link Connector, black 16 pin plug, pin 14
CAN Bus SW Dk. Green Data OBD-Data Link Connector, black 16 pin plug, pin 1
OBD 12 Volts Red/White (7.5A) + OBD-Data Link Connector, black 16 pin plug, pin 16
OBD Ground Black - OBD-Data Link Connector, black 16 pin plug, pin 4
IMMO Data Lt. Blue Data
Immobilizer Control Module on ignition switch, violet 3 pin plug, pin 2
Power Lock lt. blue (passenger door switch) - BCM under driver dash, blue 27 pin plug, pin 19
Power Unlock dk. blue (passenger door switch) - BCM under driver dash, blue 27 pin plug, pin 15
Lock Motor gray (for OEM sec upgrade, see Tech 5 wire BCM under driver dash, pink 27 pin plug, pin 4 Doc 1925)
Driver Unlock Motor gray 5 wire BCM under driver dash, pink 27 pin plug, pin 1
Passenger Unlock Motor tan 5 wire BCM under driver dash, pink 27 pin plug, pin 2
Factory Alarm Arm (arms on lock with door open)
Factory Alarm Disarm (see disarm no unlock)
Disarm No Unlock
(Passkey and ignition)
Parking Lights violet (LF); brn/wht (RF); brown (LR); + BCM under dr dash, blk 26 pin plg, pins 6, 5, 7; brn 26 pin brown (RR) plug, pin 7
Parking Lights - Lt. Blue - Headlight Switch, black 12 pin plug, pin 7
Hazards white - BCM under driver dash, blue 27 pin plug, pin 26
Turn Signal (Left) lt. blue/white (F); yellow/black (R) + BCM under driver dash, brown 26 pin plug, pins 2, 1
Turn Signal (Right) dk. blue/white (F); dk. green/white (R) + BCM under driver dash, black 26 pin plug, pins 3, 4
Headlight white (also need to trigger parking lights - headlight switch, black 12 pin plug, pin 2 (-))
AutoLights dk. green - (off) headlight switch, black 12 pin plug, pin 9
Reverse Light lt. green + BCM under driver dash, gray 26 pin plug, pin 3
Left Front Door Trigger Gray/Black - Driver Window Switch, black 8 pin plug, pin 6
Right Front Door Trigger tan/white - passenger window switch, black 8 pin plug, pin 6
Left Rear Door Trigger lt. blue/black - left rear window switch, black 8 pin plug, pin 2
Right Rear Door Trigger lt. green/black - right rear window switch, black 8 pin plug, pin 2
Dome Light gray + BCM under driver dash, gray 26 pin plug, pin 1
Trunk/Hatch Pin pink/blk (w/o pwr liftgt); pink/blk (w/pwr - BCM, pk 27 pin plg, pin 5; Liftgate Mod in liftgate, bk 16 liftgt) pin plg, pin 5
Hood Pin pink/black - BCM under driver dash, black 26 pin plug, pin 24
Power Liftgate gray/black - power liftgate switch, black 4 pin plug, pin 4
Trunk/Hatch Release gray (rear handle switch) - BCM under driver dash, pink 27 pin plug, pin 15
Trunk Release Motor lt. blue (without power liftgate) 5 wire driver kick, harness to rear
Tachometer brn, dk. blue, dk. grn, lt. blue, lt. grn, or ac any fuel injector, black 2 pin plug, pin 1 pur
Fuel Pump pink + driver kick, harness to rear
Rear Defroster white + latched above driver kick, black 43 pin plug, pin 8
Mirror Defroster (same as rear defroster)
Left Front Heated Seat (low speed GMLAN)
Right Front Heated Seat
(low speed GMLAN)
Speed Sense dk. green/white (some models only) ac radio, gray 20 pin plug, pin 20
Brake Wire white + BCM under driver dash, black 26 pin plug, pin 11
Parking Brake lt. blue - BCM under driver dash, pink 27 pin plug, pin 12
Horn Trigger tan - BCM under driver dash, brown 26 pin plug, pin 19
Wipers gray + BCM under driver dash, black 26 pin plug, pin 16
Left Front Window (Up/Down)
dk. blue - brown A driver window switch, black 8 pin plug, pins 2 - 3
Right Front Window (Up/Down)
dk. blue - brown A passenger window switch, black 8 pin plug, pins 2 - 3
Left Rear Window (Up/Down)
dk. blue - brown A left rear window switch, black 8 pin plug, pins 6 - 7
Right Rear Window (Up/Down)
dk. blue - brown A right rear window switch, black 8 pin plug, pins 6 - 7
Sun Roof (Open/Close) lt. blue (open) (functions with ignition on - 100 sunroof switch, black 4 pin plug, pin 4 only) ohms
Sun Roof (Limit/Close) (close) (same as sun roof open)
- 940 ohms
Memory Seat 1 white - 630 memory seat switch, black 6 pin plug, pin 6 ohms
Memory Seat 2 (same as memory seat 1)
-2000 ohms
Radio 12V red/white + radio, black 44 pin plug, pin 44
Radio Ground black/white - radio, black 44 pin plug, pin 38
Radio Ignition (low speed GMLAN)
Radio Illumination (low speed GMLAN)
Factory Amp Turn-on white + radio, black 44 pin plug, pin 43
Left Front Speaker (+/-) tan/white - dk. green (preamp) +,- radio, black 44 pin plug, pins 40 - 32
Note - Left Front Speaker (+/-): The speaker wires are tan - gray at the amplifier under driver dash, black 16 pin plug, pins 1 - 2.
Right Front Speaker (+/-)
lt. green/white - orange/black (preamp)
radio, black 44 pin plug, pins 39 - 31
Note - Right Front Speaker (+/-): The speaker wires are lt. green - dk. green at the amplifier under driver dash, black 16 pin plug, pins 11 - 12.
Left Rear Speaker (+/-)
brown/white - brown (preamp)
radio, black 44 pin plug, pins 42 - 34
Note - Left Rear Speaker (+/-): The speaker wires are brown - yellow at the amplifier under driver dash, black 16 pin plug, pins 3 - 4.
Right Rear Speaker (+/-)
dk. blue - tan (preamp)
radio, black 44 pin plug, pins 41 - 33
Note - Right Rear Speaker (+/-): The speaker wires are dk. blue - lt. blue at the amplifier under driver dash, black 16 pin plug, pins 10 - 9.
Center Channel (+/-)
yellow - lt. blue
amplifier under driver dash, black 16 pin plug, pins 7 - 8
Subwoofer (+/-)
dk grn - lt blu/blk(1); dk blu/wht - lt grn/blk(2)
amplifier under driver dash, black 8 pin plug, pins 3 - 2; 1 -5
Aux. Audio Input Left (+/-)
lt. green - dk. blue or yellow - dk. green/white
radio, black 44 pin plug, pins 24 - 23
Aux. Audio Input Right (+/-)
dk. green/white - dk. blue or tan/wht - dk. grn/wh
radio, black 44 pin plug, pins 10 - 23
RSE Video (+/-)
dk. green - white/black (L); lt. green - white (R)
radio, black 20 pin plug, pins 10 - 20; 8 - 18
Note - RSE Video (+/-): The rearview camera video wires are pink - lt. blue at the radio, gray 20 pin plug, pins 5 - 15.
RSE Audio Left (+/-)
lt. blue - violet
radio, black 20 pin plug, pins 1 - 2
RSE Audio Right (+/-)
white - violet
radio, black 20 pin plug, pins 11 - 2
Satellite Radio 12 Volts
(built into radio)
What Fits?
Item
Size
Depth
Location
Headunit
irregular
center of dash
Left Front Speaker
6.5
3.25
left front door
Right Front Speaker
6.5
3.25
right front door
Left Rear Speaker
6.5
3.15
left rear door
Right Rear Speaker
6.5
3.15
right rear door
Satellite Radio Tuner
(built into radio)
Gary Sather
