2020 Dodge Charger Factory Alarm, Add Shock Sensor
hsanford101
Posted: February 26, 2021 at 4:59 PM / IP Logged Link to Post Post Reply Quote hsanford101
I am looking to install a shock sensor to my factory alarm on my 2020 Dodge Charger Scat Pack can anyone help with location and wiring ?
550i/ Silverado ss
mgoetz74
Silver - Posts: 424
Posted: February 27, 2021 at 9:43 AM / IP Logged Link to Post Post Reply Quote mgoetz74
there wouldn't be a place to just add a shock sensor to the factory alarm. You'd have power/ground on the sensor and (what I have done in the past) hook the trigger wire to the door trigger, all depending on the shock sensor itself (brand). That way it has something to set off the factory alarm. been a long time since I have done that
Platinum - Posts: 13,674
Posted: February 27, 2021 at 6:56 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Do not use door trigger, when you hit a bump the sensor will make your door/dome light come on. There should be a hood pin you can catch. Give me a few I will get a wire color and polarity for you.
Posted: February 27, 2021 at 6:58 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Hood Pin      Violet/Lt. Blue      -      BCM above passenger kick, black 24 pin plug (A), pin 11
hsanford101
Posted: March 28, 2021 at 5:34 PM / IP Logged Link to Post Post Reply Quote hsanford101
Thank you I really appreciate it !
550i/ Silverado ss
hsanford101
Posted: March 28, 2021 at 5:36 PM / IP Logged Link to Post Post Reply Quote hsanford101
Is that all I need I’m using a 504d shock sensor
550i/ Silverado ss
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
