2004 Mercedes E320, Wiring Diagram For Push Button Start
rhendrickson101
Posted: April 26, 2023 at 8:03 PM / IP Logged Link to Post Post Reply Quote rhendrickson101
I can only find early 2000's for this specific year of e class. Does anyone have access to the 2004 E320 wiring diagram? Thank you!!
Also, do you know if this specific year has an immobilizer system? Would I need a bypass? I cannot find any such information on this.
lukeylikesit
Member - Posts: 20
Posted: June 13, 2023 at 4:34 PM / IP Logged Link to Post Post Reply Quote lukeylikesit
Hopefully this helps you.
2004 Mercedes Benz E Class (W211) - North America
Item     Wire Color     Polarity     Wire Location
12 Volts     red (20A)     +     Electronic Ignition Switch, 5 pin plug (C), pin 1
Second 12 Volts     red (150A)     +     driver dash fuse box
Ground     (chassis ground)
Starter     violet/white or violet (for starter kill only)     +     underhood fuse box, 6 pin plug (B2), pin 5
Ignition     pink/red (for ignition sense only)     + low curr     Electronic Ignition Switch, 5 pin plug (C), pin 2
CAN Bus High     brown/red     data     Central Gateway Module under driver dash, 10 pin plug, pin 10
CAN Bus Low     brown     data     Central Gateway Module under driver dash, 10 pin plug, pin 9
Power Lock     (CAN bus)
Power Unlock     (CAN bus)
Lock Motor     black     5 wire     Left Front Door Module, plug (C5), pin 3
Driver Unlock Motor     red     5 wire     Left Front Door Module, plug (C5), pin 2
Factory Alarm Arm     (factory remote only)
Factory Alarm Disarm     (factory remote only)
Parking Lights     gray/black (LF), gray/red (RF)     +     underhood fuse box, 4 pin plug (I12), pins 1 and 2
Note - Parking Lights: The LR - RR are gray/black - gray/red, or black/red - black/red, at the trunk fuse box, 14 pin plug (C14), pins 4 - 10.
Hazards     (CAN bus)
Turn Signal (Left)     black/white (LF)     +     underhood fuse box, 10 pin plug (M3), pin 5
Note - Turn Signal (Left): The (LR) is black/white at the trunk fuse box, 14 pin plug (C14), pin 11.
Turn Signal (Right)     black/green (RF)     +     Passenger Side SAM on pass floorboard, 6 pin plug (I3), pin 1
Note - Turn Signal (Right): The (RR) is black/green at the trunk fuse box, 14 pin plug (C14), pin 3.
Headlight     yellow/black (L)     +     underhood fuse box, 10 pin plug (M3), pin 2
Note - Headlight: The (R) is yellow at the Passenger Side SAM on passenger floorboard, 6 pin plug (I3), pin 6.
Reverse Light     gray/yellow     +     trunk fuse box, 14 pin plug (C14), pin 8
Left Front Door Trigger     brown/yellow     -     trunk fuse box, 12 pin plug (C2), pin 9
Right Front Door Trigger     brown/white     -     trunk fuse box, 12 pin plug (C2), pin 8
Left Rear Door Trigger     brown/blue     -     trunk fuse box, 12 pin plug (C2), pin 11
Right Rear Door Trigger     brown/violet     -     trunk fuse box, 12 pin plug (C2), pin 10
Dome Light     (CAN bus)
Trunk/Hatch Pin     green     -     trunk fuse box, 28 pin plug (C21), pin 4
Hood Pin     brown/red     -     trunk fuse box, 8 pin plug (C4), pin 1
Trunk/Hatch Release     gray/yellow (rear handle switch)     -     trunk fuse box, 28 pin plug (C21), pin 5
Trunk Release Motor     red/brown or gray/pink     5 wire     trunk fuse box, 28 pin plug (C21), pin 11 or 7
Fuel Door Release     brown or red/yellow     5 wire     trunk fuse box, 4 pin plug (C13), pin 2 or 3
Tachometer     gray/stripe     ac     any fuel injector
Fuel Pump     red/green     +     trunk fuse box, 7 pin plug (C1), pin 3
Rear Defroster     red/yellow     + latched     trunk fuse box, 5 pin plug (C20), pin 5
Mirror Defroster     (CAN bus)
Left Front Heated Seat     white/green     5 wire     Seat Ventilation Module under driver seat, 6 pin plug (C1), pin 3
Right Front Heated Seat     white/gray     5 wire     Seat Ventilation Module under driver seat, 6 pin plug (C1), pin 4
Speed Sense     (wheel speed sensor)
Brake Wire     black/red     +     brake switch, 2 pin plug, pin 2
Parking Brake     brown/white     -     parking brake switch, 2 pin plug, pin 1
Horn Trigger     yellow     +     underhood fuse box, 14 pin plug (M2), pin 10
Wipers     (LIN bus)
Memory Seat 1     (LIN bus)
Memory Seat 2     (LIN bus)
Memory Seat 3     (LIN bus)
Friday, June 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
