2024 Kia Sportade, Alarm/Remote Start Wiring
Home /
the12volt's Install Bay /
Vehicle Wiring Information & File Requests / 2024 Kia Sportade, Alarm/Remote Start Wiring
Welcome Guest :)
Posted: May 22, 2024 at 5:43 PM / IP Logged
Item Wire Color Polarity Wire Location Photo Note
12 Volts Black (50A) + ICU Junction Block-Dash Fuse Box, white 4 pin plug (A), pin 1 Directwire
Ground (chassis ground)
Starter Pink + Driver Kick, gray 54 pin plug (EM11), pin 33 Directwire
Ignition Black + ICU Junction Block-Dash Fuse Box, white 58 pin plug (B), pin 21 Directwire
Accessory Red + ICU Junction Block-Dash Fuse Box, white 58 pin plug (B), pin 38 Directwire
Second Accessory Black + ICU Junction Block-Dash Fuse Box, white 58 pin plug (B), pin 48 Directwire
Ignition Interrupt Yellow Cut ICU Junction Block-Dash Fuse Box, rear, white 47 pin plug (F), pin 45 Directwire
PTS 1 Yellow/Orange - Start Stop Button Switch, white 10 pin plug, pin 1
PTS 2 Orange/Black - Start Stop Button Switch, white 10 pin plug, pin 7
PTS 3 Yellow/Orange (PTS 1 alternate) - Passenger Kick, red 74 pin plug (MF21), pin 62 Directwire
PTS 4 Orange/Black (PTS 2 alternate) - Passenger Kick, red 74 pin plug (MF21), pin 71 Directwire
CAN Bus High Pink (D-CAN) Data ICU Junction Block-Dash Fuse Box, rear, white 32 pin plug (H), pin 21 Directwire
CAN Bus Low Gray (D-CAN) Data ICU Junction Block-Dash Fuse Box, rear, white 32 pin plug (H), pin 22 Directwire
CAN Bus High 2 Red (B-CAN) Data ICU Junction Block-Dash Fuse Box, rear, white 32 pin plug (H), pin 24 Directwire Notes
CAN Bus Low 2 Blue (B-CAN) Data ICU Junction Block-Dash Fuse Box, rear, white 32 pin plug (H), pin 23 Directwire Notes
CAN Bus High 3 Pink (D-CAN) Data OBD-Data Link Connector, black 16 pin plug, pin 6 Directwire
CAN Bus Low 3 Gray (D-CAN) Data OBD-Data Link Connector, black 16 pin plug, pin 14 Directwire
CAN Bus High 4 Yellow (M-CAN) Data ICU Junction Block-Dash Fuse Box, rear, white 32 pin plug (H), pin 20 Directwire
CAN Bus Low 4 Black (M-CAN) Data ICU Junction Block-Dash Fuse Box, rear, white 32 pin plug (H), pin 19 Directwire
OBD 12 Volts Red (10A) + OBD-Data Link Connector, black 16 pin plug, pin 16 Directwire
OBD Ground Black - OBD-Data Link Connector, black 16 pin plug, pin 4 Directwire
OBD Ignition Red/Orange or Green/Orange + OBD-Data Link Connector, black 16 pin plug, pin 3 Directwire
OBD Connector Black Under Driver Dash, Right of Fuse Panel
IMMO Data White/Orange Data Driver Kick, gray 54 pin plug (EM11), pin 20 Directwire
Power Lock Orange - ICU Junction Block-Dash Fuse Box, white 32 pin plug (C), pin 13 Directwire
Power Unlock Yellow - ICU Junction Block-Dash Fuse Box, red 58 pin plug (D), pin 44 Directwire
Lock Motor Brown Reverse ICU Junction Block-Dash Fuse Box, white 24 pin plug (E), pin 20 Directwire
Driver Unlock Motor Gray Reverse ICU Junction Block-Dash Fuse Box, white 24 pin plug (E), pin 24 Directwire
Passenger Unlock Motor Gray Reverse ICU Junction Block-Dash Fuse Box, white 24 pin plug (E), pin 22 Directwire
Factory Alarm Arm (factory remote only)
Factory Alarm Disarm (proximity key and push button)
Lock Detection Brown Open ICU Junction Block-Dash Fuse Box, red 58 pin plug (D), pin 45 Directwire
Unlock Detection (same as lock detection) -
Parking Lights White/Black (LF); Brown (RF) + ICU Junction Block-Dash Fuse Box, white 58 pin plug (B), pin 24 (LF); pin 14 (RF) Directwire
Parking Lights 2 Pink (LR); Yellow (RR) + ICU Junction Block-Dash Fuse Box, white 24 pin plug (E), pin 1 (LR); pin 2 (RR) Directwire
Parking Lights - Blue - 5580 Ohms Headlight-Wiper Switch, white 16 pin plug, pin 10 Directwire
Parking Lights MUX Blue MUX Headlight-Wiper Switch, white 16 pin plug, pin 10 Directwire
Hazards Brown - ICU Junction Block-Dash Fuse Box, rear, white 32 pin plug (H), pin 3 Directwire
Hazards 2 Brown (alternate location) - Hazard Switch, black 6 pin plug, pin 3
Turn Signal (Left) Yellow (LF); Gray (LR) + ICU Junction Block-Dash Fuse Box, white 58 pin plug (B), pin 6 (LF); white 24 pin plug (E), pin 6 (LR) Directwire
Turn Signal (Right) White (RF); Blue (RR) + ICU Junction Block-Dash Fuse Box, white 58 pin plug (B), pin 43 (RF); white 24 pin plug (E), pin 5 (RR) Directwire
Headlight Blue/Orange - Headlight-Wiper Switch, white 16 pin plug, pin 2 Directwire
AutoLights Blue - 680 Ohms (Off) Headlight-Wiper Switch, white 16 pin plug, pin 10 Directwire
Reverse Light Gray + ICU Junction Block-Dash Fuse Box, white 24 pin plug (E), pin 9 Directwire
Left Front Door Trigger Yellow/Orange - ICU Junction Block-Dash Fuse Box, red 58 pin plug (D), pin 36 Directwire
Right Front Door Trigger White - ICU Junction Block-Dash Fuse Box, red 58 pin plug (D), pin 35 Directwire
Left Rear Door Trigger Red - ICU Junction Block-Dash Fuse Box, white 32 pin plug (C), pin 27 Directwire
Right Rear Door Trigger Gray/Black - ICU Junction Block-Dash Fuse Box, white 32 pin plug (C), pin 26 Directwire
Dome Light Brown - ICU Junction Block-Dash Fuse Box, rear, white 47 pin plug (F), pin 5 Directwire
Trunk/Hatch Pin White - ICU Junction Block-Dash Fuse Box, white 32 pin plug (C), pin 12 Directwire
Hood Pin Red - ICU Junction Block-Dash Fuse Box, white 58 pin plug (B), pin 25 Directwire
Power Liftgate Green/Black - Power Liftgate Switch, white 24 pin plug, pin 7 Directwire
Power Liftgate 2 Green/Black (alternate location) - Driver Kick, red 74 pin plug (MF11), pin 71
Trunk/Hatch Release Green or Gray (rear handle switch) - ICU Junction Block-Dash Fuse Box, white 32 pin plug (C), pin 11 Directwire
Trunk Release Motor Red (w/o power liftgate) + ICU Junction Block-Dash Fuse Box, red 58 pin plug (D), pin 14 Directwire
Fuel Door Release (locks-unlocks with driver door)
Tachometer Green AC Driver Kick, gray 54 pin plug (EM11), pin 23 Directwire
Tachometer 2 Brown AC Camshaft Position Sensor, engine driver side front, black 3 pin plug, pin 1
Fuel Pump Green + Driver Kick, white 51 pin plug (EF11), pin 13 Directwire
Rear Defroster Green/Orange - Latched ICU Junction Block-Dash Fuse Box, white 58 pin plug (B), pin 46 Directwire
Mirror Defroster (same as rear defroster)
Wiper Deicer Blue - Latched ICU Junction Block-Dash Fuse Box, white 58 pin plug (B), pin 8 Directwire
Left Front Heated Seat Gray/Orange (w/o ventilation) - Console Switch, white 16 pin plug, pin 6
Right Front Heated Seat Red (w/o ventilation) - Console Switch, white 16 pin plug, pin 7
Left Front Heated Seat 2 (LIN with ventilation)
Right Front Heated Seat 2 (LIN with ventilation)
Heated Steering Wheel Gray/Black - Console Switch, white 16 pin plug, pin 4
Speed Sense Gray/Black AC Radio, white 38 pin plug, pin 38
Brake Wire Green + Brake Switch, black 6 pin plug, pin 5
Brake Wire 2 Green (alternate location) + ICU Junction Block-Dash Fuse Box, white 58 pin plug (B), pin 10 Directwire
Parking Brake Gray/Black (w/o EPB) - ICU Junction Block-Dash Fuse Box, white 58 pin plug (B), pin 37
Horn Trigger Gray - Driver Kick, gray 54 pin plug (EM11), pin 7 Directwire
Horn Trigger 2 Gray (alternate location) - Horn Switch-Clock Spring, white 14 pin plug, pin 8
Horn - Factory Alarm Gray - ICU Junction Block-Dash Fuse Box, white 58 pin plug (B), pin 45 Directwire
Wipers White/Orange + Passenger Kick, blue 54 pin plug (EM21), pin 32
Left Front Window (Up/Down) Yellow - Orange (auto down); (auto up-down, motor is part of module) A Power Window Main Switch, white 18 pin plug, pins 9 - 7
Right Front Window (Up/Down) Brown - White (w/o auto); (with auto, motor is part of module) A Driver Kick, door harness
Left Rear Window (Up/Down) Blue - Orange A Driver Kick, door harness
Right Rear Window (Up/Down) Pink - Blue A Driver Kick, door harness
Sun Roof (Open/Close) White and Blue (open) (functions with ignition on only) Both - Left Front Pillar, white 44 pin plug (MR11), pins 17, 44
Sun Roof (Limit/Close) Blue and Red (close) (functions with ignition on only) Both - Left Front Pillar, white 44 pin plug (MR11), pins 44, 4
Memory Seat 1 Orange - 1500 Ohms Driver Kick, door harness
Memory Seat 2 (same as memory seat 1) - 3300 Ohms
Radio 12V Red + Radio, gray 35 pin plug, pins 10, 11
Radio Ground Black - Radio, gray 35 pin plug, pins 12, 13
Radio Ignition Blue/Orange + Radio, gray 35 pin plug, pin 22
Radio Illumination Pink (parking lights); Gray (dimmer) +,- Radio, gray 35 pin plug, pin 6 (parking lights); pin 19 (dimmer)
Factory Amp Turn-on (M-CAN) (audio is SPDIF)
Left Front Speaker (+/-) White - Black +,- Radio, white 38 pin plug, pins 13 - 14
Right Front Speaker (+/-) Red - Green +,- Radio, white 38 pin plug, pins 16 - 15
Left Rear Speaker (+/-) Yellow - Brown +,- Radio, white 38 pin plug, pins 1 - 2
Right Rear Speaker (+/-) Orange - Gray +,- Radio, white 38 pin plug, pins 28 - 27
Left Front Speaker - With Amp White - Black +,- Amplifier under passenger seat, white 28 pin plug, pins 12 - 13
Right Front Speaker - With Amp Red - Green +,- Amplifier under passenger seat, white 28 pin plug, pins 14 - 15
Left Rear Speaker - With Amp Yellow - Brown +,- Amplifier under passenger seat, black 28 pin plug, pins 1 - 2
Right Rear Speaker - With Amp Orange - Gray +,- Amplifier under passenger seat, black 28 pin plug, pins 3 - 4
Center Channel - With Amp Pink - Yellow +,- Amplifier under passenger seat, white 28 pin plug, pins 27 - 28
Subwoofer - With Amp Green - Red (coil 1); White - Black (coil 2) +,- Amplifier under passenger seat, black 28 pin plug, pins 18 - 19 (coil 1); pins 16 - 17 (coil 2)
Rearview Camera Video White - Green (rear view); (COAX, surround view) +,- Radio, white 38 pin plug, pins 7 - 21 Gary Sather
If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Search the12volt.com |
Friday, May 31, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
