Need wiring information for 98 Chevy Cavalier Z24
Welcome Guest :)
whcollier
Member -
Posted: July 24, 2002 at 7:00 PM / IP Logged
does anyone know the wiring diagrams and color codes for a 1998 Chevy Cavalier Z24???? we need to install aftermarket stereo system and alarm/remote start/keyless entry system in it thanks in advance for any and all information provided
Bill
Just another Gadget Junkie
dan768
Copper -
Posted: July 24, 2002 at 11:10 PM / IP Logged
I got something
Year(s): 95-00 | Make(s): Chevrolet/Pontiac | Model(s): Cavalier |
12 Volt (+) | 12ga. Red in main harness under left side of dash which exits through firewall |
Ignition 1 | 12ga. Pink at same |
Ignition 2 | 12ga. White at same |
Ignition 3 | 12ga. Orange at same |
Accessory 1 | 12ga. Brown at same |
Accessory 2 | |
Starter | 12ga. Yellow at same |
Horn | 18ga. Black (-) at same (the horn wire actually runs down from the dash into this harness, look for this wire there before it enters the main harness |
Tachometer | 18ga. White or Violet/White at PCM in passenger’s kick panel |
Lights (+) | 18ga. Brown at main harness under left side of dash |
Lights (-) | |
Brake Lights | 18ga. White (+) at brake pedal switch |
Door 1 | 18ga. GREEN/ Black (-) (driver door only) at driver’s kick panel leading into pin switch |
Door 2 | 18ga. Lt. Blue (-) (passenger doors) at driver’s kick panel in Blue/Black connector (may be behind carpeting) |
Door 3 | |
Door 4 | |
Interior Lights | 18ga. White (-) at main harness under left side of dash |
Trunk/Hatch | 18ga. Black (+) at trunk light |
Hood Pin | |
Trunk Release | 16ga. BLACK/ White (+) at R.K.E. in left rear ¼ panel behind trunk liner (when equipped with R.K.E.) |
Lock (switch) | 18ga. Lt. Blue (+) at driver’s kick panel (for non keyless entry models wires will be 16ga. Lt. Blue and Blue reverse polarity resting negative) |
Unlock (switch) | 18ga. White (+) at same |
Driver Unlock | |
Arm (key) | |
Disarm (key) | |
Arm Input | 14ga. Gray (M) at driver’s kick panel |
Disarm Input 1 | 14ga. Tan (M) at same |
Disarm Input 2 | 18ga. White (Sw) at same |
dan
Remember (there are no hard cars,some just take longer to install on then others)
Saturday, June 1, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
