99 F350 keyless module location
tja350
Posted: February 21, 2004 at 3:29 PM / IP Logged
I'm trying to find the keyless entry module in my 1999 F350 super duty crew cab 4x4. I've installed a DEI remote starter module and I need to find the ignition wire that goes to the keyless entry so I can connect it to the ignition sense wire from the DEI piece. The starter module is energized by pulsing the door lock button twice. When the truck starts the keyless will not operate. Any info would be very much appreciated.
Pcourmier
Member - Posts: 8
Posted: February 23, 2004 at 9:02 PM / IP Logged
ItemWire ColorPolarityWire Location
12VyellowPositive (+)ignition harness
StarterRED / lt. bluePositive (+)ignition harness
Starter 2none
IgnitionRED / black [5]Positive (+)ignition harness
2nd Ignitionnone
3rd Ignitionnone
AccessoryBLACK/ greenPositive (+)ignition harness
Accessory 2gray / YELLOWPositive (+)ignition harness
TachometerWHITE/ pinkinstrument cluster or [3]
Power Door (Lock)
Wiring Diagram for
[[1]] Door Lock
pink / YELLOW[1][1]
Power Door (Unlock)
Wiring Diagram for
[[1]] Door Unlock
pink/green[1][1]
Door TriggerBLACK/ lt. bluePositive (+)[2]
Dome Supervision
Wiring Diagram for
[none] Dome
nonenonenone
HeadlightsRED / yellowPositive (+)headlight switch
Parklight PositivebrownPositive (+)headlight switch
Parklight Negativenone
Wiperswhite - dk.blu/ornPositive (+)motor or relay
Left Front Window
(Up/Down)
wht/blk - tan/bludrivers door switch
Right Front Window
(Up/Down)
tan/blu - wht/yeldrivers door switch
Left Rear Window
(Up/Down)
yel/blu - gry/ornAdrivers door switch
Right Rear Window
(Up/Down)
RED / blk - yel/blkAdrivers door switch
Trunk/Hatch Pinnonenonenone
Hood Pinnone
Trunk/Hatch Release
Wiring Diagram for
[none] Trunk/Hatch
nonenonenone
Factory Alarm
(Arm)
nonenonenone
Factory Alarm
(Disarm)
nonenonenone
Horndk. blueNegative (-)steering column
Brakelt. greenPositive (+)brake switch
Door Motor
(Lock)
pink/blackdrivers kick panel
Door Motor
(Unlock)
pnk/blk or RED / orgdrivers kick panel
Disarmpink/orangepassengers kick panel
Disarm No Unlocknonenonenone
99 F350 keyless module location -- posted image.
Additional Info:
Note : Diesel glow plug wire is a BLACK/ pink(-), the wire MUST be diode isolated from the instrument cluster to keep the battery from draining. The tach wire is a WHITE/ pink. Both wires are located at the PCM or can also be located in the main harness that runs on the inside of the firewall to the left of the brake pedal. [1] Non-keyless versions are 5 wire located in the drivers door harness. Keyless versions are negative trigger located in a gray molex plug to the right side of the steering column [2] Located in a gray molex plug to the right side of the steering column. [3] Tach can also be located in the main harness that runs on the inside of the firewall to the left of the brake pedal. [4] PCM is located on the left side of fire wall. [5] There are two RED / black wires at the ignition harness, use the heavier gauge wire of the two.
