1999 Toyota 4-Runner alarm diagram
dieggo98
Member - Posts: 14
Posted: March 26, 2004 at 9:27 PM / IP Logged
I am about to install an alarm/remote entry system on a 1999 toyota forerunner. If anyone has wiring diagram and location of wires for factory installed unit for said vehicle I would greatly appreciate you sharing that with me. The system I'm installing, the commando 5005, has the output leads to arm and disarm factory systems but of course I need to know where to start.
Thank you.
boomer_106
Silver - Posts: 710
Posted: March 27, 2004 at 1:45 PM / IP Logged
Toyota
4-Runner
1999-2002
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
GREEN/ BLACK
IGNITION SWITCH HARNESS *
Ignition #1:
BLACK/ RED
Ignition #2:
BLACK / YELLOW
Ignition #3:
N/A
Accessory:
BLUE/RED
Brake Light:
GREEN / WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
BLACK
AT IGNITER ON PASS. WHEELWELL **
Parking Lights:
RED / GREEN (-)
AT ALARM MODULE
Headlights:
RED (-)
AT HEADLIGHT SWITCH ***
OEM Alarm Disarm:
N/A
OEM Alarm Arm:
BLACK / YELLOW (+)
AT ALARM MODULE
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
* 2000 Vehicles May Be Equipped With a Transponder Type ** BLACK Tach Wire Also Found In Data Link Connector On Driver Side Of Engine (4 Cyld.) Or At Engine Control Module Located Behind Pass. Dash (6 Cyld.) Or Can Also Be Found In 26 Pin Connector In Pass. Kick Panel On Both.
Toyota
4-Runner
1999-2002
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
WHITE/ RED & WHITE
Starter Kill:
GREEN/ BLACK
Ignition +12 Volts:
BLACK/ RED
Dome Lights/Superv:
GREEN/ BLACK (-)
AT DOME LIGHT
OEM Horn:
GREEN/ RED (-)
AT ALARM MODULE
Power Lock:
RED / WHITE (-)
WHITE CONN. ABOVE BLUE IN DR. KICK***
Power Unlock:
RED (-)
Trunk Release:
Alarm Input Wire:
GREEN/ BLACK (-)
AT DOME LIGHT
Notes:
** Fuse Block Located In Driver Dash. *** Child Safety Locks: RED / BLUE (-) In Same Conn. As Door Lock Wires Above. See Note #209 - See Child Safety Locks Diagram. Lock Wires Are Also Found At Alarm Module. Lock BROWN / White (-) Unlock GREEN/ YELLOW (-)
dieggo98
Member - Posts: 14
Posted: March 31, 2004 at 9:23 AM / IP Logged
thanks, boomer_106. I really appreciate that.
Friday, January 30, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
