1996 Mustang Remote Start
Welcome Guest :)
jrd_audio
Member -
Posted: April 05, 2004 at 11:09 AM / IP Logged
I have a 1996 Mustang with a DEI Sidewinder alarm in it at the time. I am looking to install a remote start sytem to it. I was wondering how this would be done. The Sidewinder version I have does not have remote start and my car is a manual tranny. Thanks
boomer_106
Silver -
Posted: April 05, 2004 at 10:57 PM / IP Logged
Here is the wiring info for that car.
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | WHITE/ PINK | IGNITION SWITCH HARNESS * |
Ignition #1: | | TAN/WHITE | IGNITION SWITCH HARNESS |
Ignition #2: | | GRAY / YELLOW (# AWG) | IGNITION SWITCH HARNESS ** |
Ignition #3: | | GRAY / YELLOW-2WIRES | IGNITION SWITCH HARNESS *** |
Accessory: | | BLACK/ L GREEN | IGNITION SWITCH HARNESS |
Brake Light: | | RED / L GREEN (+) | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | ORANGE / WHITE | PIN ## AT POWERTRAIN CONTROL MODULE* |
Parking Lights: | | BROWN (+) | AT HEADLIGHT SWITCH |
Headlights: | | RED / YELLOW (+) | AT HEADLIGHT SWITCH |
OEM Alarm Disarm: | | D GREEN/ PURPLE (-) | BLACK # PIN CONN. DR. KICK PANEL |
OEM Alarm Arm: | | N/A | |
Diesel Glow Plug: | | | |
Clutch Bypass Wire: | | | |
Notes: | | * Powertrain Control Module Located In Passenger Kick Panel. ** 1997 + GT Models Are Equipped With Ford's PATS Anti-Theft System. See Installation Note #144 - Bypassing Transponder Theft Systems. *** See Note #127 - Ford Ignition Switch Connection Diagram. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | YELLOW (5) | IGNITION SWITCH HARNESS |
Starter Kill: | | WHITE/ PINK | IGNITION SWITCH HARNESS * |
Ignition +12 Volts: | | TAN/WHITE | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | BLACK/ L BLUE (+) | GRAY # PIN PLUG IN DR. KICK PANEL**** |
OEM Horn: | | PURPLE / ORANGE (-) | STEERING COLUMN HARNESS |
Power Lock: | | PINK / YELLOW | # PIN BLACK CONNECTOR ***** |
Power Unlock: | | PINK/LT GREEN | HIGH IN DRIVER OR PASS. KICK PANEL |
Trunk Release: | | PURPLE / YELLOW (+) | AT TRUNK RELEASE SWITCH |
Alarm Input Wire: | | BLACK/ L BLUE (+) | GRAY # PIN PLUG IN DR. KICK PANEL**** |
Notes: | | **** With OEM Keyless Entry Dome Light Wire Is GRAY (+) In 12 Pin Gray Connector In Driver Kick Panel. ****** Without OEM Keyless Entry See Note #203 - Reverse Polarity Door Lock Diagram, With OEM Keyless See Note #202 - Positive Pulse Door Lock Diagram. |
Saturday, June 1, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
