starter cut
Welcome Guest :)
endubho
Member -
Posted: December 04, 2004 at 9:50 PM / IP Logged
how do i wire the starter cut relay and where??????what kinda relay ineed for 1990 intregra LS
Mja1962
Copper -
Posted: December 04, 2004 at 11:06 PM / IP Logged
https://www.the12volt.com/relays/page2.asp
http://www.designtech-intl.com/Content/techsupport/wirecolors/VehicleDetail?modelID=11
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | BLACK/ WHITE | IGNITION SWITCH HARNESS |
Ignition #1: | | BLACK / YELLOW | IGNITION SWITCH HARNESS |
Ignition #2: | | YELLOW | IGNITION SWITCH HARNESS |
Ignition #3: | | BLUE/WHITE | IGNITION SWITCH HARNESS |
Accessory: | | WHITE/ RED | IGNITION SWITCH HARNESS |
Brake Light: | | GREEN / WHITE (+) | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | BLUE | AT COIL |
Parking Lights: | | RED / GREEN (+) | AT HEADLIGHT SWITCH |
Headlights: | | RED / YELLOW (+) | AT HEADLIGHT SWITCH |
Diesel Glow Plug: | | N/A | N/A |
Clutch Bypass Wire: | | N/A | N/A |
Notes: | | |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | WHITE/ BLACK | IGNITION SWITCH HARNESS |
OEM Alarm Disarm: | | N/A | IN SCHEMATICS |
Dome Lights/Superv: | | GREEN/ RED (-) | PASSENGER PIN SWITCH |
OEM Horn: | | BLUE/RED (-) | STEERING COLUMN HARNESS |
Power Lock: | | GREEN / WHITE | DRIVER'S KICK |
Power Unlock: | | GREEN/ RED | PANEL* |
Trunk Release: | | N/A | |
Alarm Input Wire: | | GREEN/ RED (-) | PASSENGER PIN SWITCH |
Notes: | | * See Note #201- Negative Pulse Door Lock Diagram. |
DesignTech International, Inc. | Tel: (703) 866-2000 Fax: (703) 866-2001 | ©2002 All Rights Reserved |
7955 Cameron Brown Court Springfield, Virginia 22153 USA | 1-800-DESIGNTECH (1-800-337-4468) | DesignTech International, Inc. www.designtech-intl.com |
DesignTech disclaims any liability or responsibility arising out of any inaccuracies of this information or use of this information for installations or otherwise. Please verify all wiring for accuracy prior to making any connections |
Saturday, June 1, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
