2001 Suzuki Grand Vitara XL-7, Alarm/Stereo Wiring
Aznpanther98
Member - Posts: 36
Posted: August 15, 2005 at 10:24 PM / IP Logged
i need an alarm diagram for the 2001 suzuki grand vitara xl-7 Thanks!
thepencil
Gold - Posts: 1,526
Posted: August 16, 2005 at 8:16 AM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|WHITE/ green        |+ |ignition harness            |
|          STARTER|blk/red or blk/yel |+ |ignition harness            |
|        IGNITION|BLACK/ blue          |+ |ignition harness            |
| SECOND IGNITION|blue/black          |+ |ignition harness            |
|        ACCESSORY|yellow/black        |+ |ignition harness            |
| SECOND ACCESSORY|blue *1             |+ |ignition harness            |
|       POWER LOCK|pink               |- |door lock controller *5     |
|     POWER UNLOCK|pink/green *6       |- |door lock controller *5     |
|       LOCK MOTOR|blue               |   |keyless entry module *3     |
|     UNLOCK MOTOR|blue/white          |   |keyless entry module *3     |
|    DISARM DEFEAT|blue/red            |   |keyless entry module *3     |
| PARKING LIGHTS +|RED / yellow          |   |black plug at the fuse box |
| PARKING LIGHTS -|RED / blue            |   |headlight switch *2        |
|       HEADLIGHTS|gray/black          |- |headlight switch            |
|     DOOR TRIGGER|BLACK/ red           |- |wht plug at the fuse box *2 |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|tied in w/ door     |   |                            |
|       TACHOMETER|brown               |   |instrument cluster or ECM *4|
|      SPEED SENSE|blue / YELLOW        |4 |instrument cluster or ECM *4|
|       BRAKE WIRE|GREEN / WHITE        |+ |brake pedal switch          |
|     HORN TRIGGER|blu/orn or blu/grn |- |steering column *2          |
|           WIPERS|blue(L), blue/red(H)|+ |steering column             |
| LF WINDOW UP/DN|yellow - red        |A |drivers window switch       |
| RF WINDOW UP/DN|grn/blk - RED / blk   |A |drivers door harness        |
| LR WINDOW UP/DN|grn/yel - RED / yel   |A |drivers door harness        |
| RR WINDOW UP/DN|grn/wht - RED / wht   |A |drivers door harness        |
|        RADIO 12V|white               |+ |radio                      |
|     RADIO GROUND|black               |- |radio                      |
|     RADIO SWITCH|WHITE/ black        |+ |radio                      |
| RADIO ILLUMINATE|RED / yellow          |+ |radio                      |
|       LF SPEAKER|brn/blk - brn/wht   |   |radio                      |
|       RF SPEAKER|orange - org/blu    |   |radio                      |
|       LR SPEAKER|lt grn - lt grn/blk |   |radio                      |
|       RR SPEAKER|gray - gry/blk      |   |radio                      |
Notes:
*1 Not required for remote start. *2 Also located at the keyless entry module, if equipped. *3 The keyless entry module is located above the driver kick panel. *4 The ECM is located behind the glove box.    *5 The door lock controller is to the right of the brake pedal. *6 Unlock may require a double pulse on some models.
Be careful whose advice you buy, but be patient with those who supply it.2001 Suzuki Grand Vitara XL-7, Alarm/Stereo Wiring -- posted image.
Aznpanther98
Member - Posts: 36
Posted: August 16, 2005 at 7:15 PM / IP Logged
Thanks!
thepencil
Gold - Posts: 1,526
Posted: August 16, 2005 at 11:15 PM / IP Logged
You are welcome.
