'02 Silverado 5.3 wiring code
Anderson463
Member - Posts: 21
Posted: November 15, 2005 at 7:26 AM / IP Logged
Hello all, just getting ready to install a AstroStart model#2205 in my Chevy and was wondering if I could get some help with the wiring diagrams. I Also bought the pass key bypass as well. Is there any helpful tips or hints about installing this model that anyone would like to share? Thanks in advance
KarTuneMan
Platinum - Posts: 7,056
Posted: November 15, 2005 at 8:09 AM / IP Logged
Tach wire..white wire @ PCM under hood, pin 10 set the unit for 4 cyl. and reduce rpm to 600.
Use the P-5 for second Ign. and a programable output on the P-2 to trigger a relay for second Accessory.
Have you installed before? Have you installed any Astro before....This truck is a breeze'02 Silverado 5.3 wiring code -- posted image.  Whereabouts in the US did you get your product?
Anderson463
Member - Posts: 21
Posted: November 15, 2005 at 10:03 AM / IP Logged
I am in Minnesota. Do I even need to hook up for  the second Acc? All I want to do is run the heat/ac.
KarTuneMan
Posted: November 15, 2005 at 11:55 AM / IP Logged
That'll work....
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
