2006 Kia Sorento Alarm/Remote Start Wiring
brianh
Silver - Posts: 516
Posted: May 23, 2006 at 10:36 PM / IP Logged
Just purchased this vehicle and am planning to put a R.S on it with window role up modules. Cant find any new wiring info on it though. If anyone has any tips or suggestions for this install please let me know. Thanks in advance.
                                      Brian
spookiestylez
Silver - Posts: 531
Posted: May 23, 2006 at 10:39 PM / IP Logged
12volts green (40A), blue (30A)  +  ignition harness
Starter red  +  ignition harness
Second Starter N/A
Ignition yellow  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory orange  +  ignition harness
Second Accessory white  +  ignition harness
Keysense yellow/orange  +  ign harn or ETACS, 15 pin plg, pin 3
Notes: The ETACS (Electronic Time and Alarm Control System) module is behind the radio.
Power Lock blue  -  DKP or ETACS, 23 pin plug, pin 4
Power Unlock white  -  DKP or ETACS, 23 pin plug, pin 14
Lock Motor red  5wi relay above driver kick
Unlock Motor white  5wi DKP or ETACS, 14 pin plug, pin 5
Parking Lights+ red  +  driver kick, harness to rear
Parking Lights- white  -  switch or ETACS, 23 pin plug, pin 1
Hazards yellow  -  relay or ETACS, 23 pin plug, pin 19
Turn Signal(L) red  +  turn signal switch
Turn Signal(R) orange  +  turn signal switch
Reverse Light blue/black  +  driver kick, harness to rear
Door Trigger yellow (door ajar indicator)  -  cluster or ETACS, 23 pin plg, pin 16
The individual door trigger wires are also at the ETACS module, in the 15 pin plug. The LF door is blue in pin 4. The RF door is GREEN/ black in pin 12. The rear doors are blue/black in pin 11. Use all three wires and diode isolate each.
Dome Supervision RED / black  -  DKP or ETACS, 14 pin plug, pin 11
Trunk/Hatch Pin GREEN/ orange (ajar indicator)  -  cluster or ETACS, 14 pin plg, pin 10
Hood Pin N/A
Trunk/Hatch Release RED / orange  -  relay or ETACS, 14 pin plug, pin 3
Notes: The hatch release relay is above the driver kick.
Power Sliding Door N/A
Factory Alarm Arm green  -  DKP or ETACS, 23 pin plug, pin 5
Factory Alarm Disarm orange  -  DKP or ETACS, 23 pin plug, pin 15
Disarm No Unlock see factory alarm disarm
Tachometer GREEN/ black  ac  cluster or ECM, 28 pin plug, pin 5
Notes: The ECM (Engine Control Module) is behind the glovebox.
Wait to start N/A
Brake Wire white  +  brake pedal switch
Parking Brake orange  -  parking brake switch or cluster
Horn Trigger blue/black  -  switch or ETACS, 23 pin plug, pin 6
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
2006 Kia Sorento Alarm/Remote Start Wiring -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
No
Type:
N/A
Part #: N/A
Notes:
brianh
Silver - Posts: 516
Posted: May 24, 2006 at 5:07 PM / IP Logged
Thanks for the wiring info. That helps out alot. Does anyone have the power window wire colors for up and down?          Brian
Monday, June 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
