2005 h2 alarm/remote start
MasterInstall2
Posted: September 11, 2007 at 12:08 AM / IP Logged
Looked in downloads section and did not see anything older that 2007 H2.  Thanks in advance!
KarTuneMan
Platinum - Posts: 7,056
Posted: September 12, 2007 at 11:54 AM / IP Logged
PASSIVE ANTI-THEFT YES PASSLOCK 2   SEE NOTES
 12 VOLTS Red Ignition switch harness   +
 Many parts must be removed from the dash to access the area below the steering column. Please refer to the dash disassembly document for complete instructions.
 IGNITION Pink Ignition switch harness   +
 IGNITION 2 White Ignition switch harness   +
 ACCESSORY Orange Ignition switch harness   +
 STARTER Yellow Ignition switch harness   +
 KEY SENSE Lt.green At steering column   -
 TACH SIGNAL SEE NOTES
 Each of the coils has 4 wires. A Pink, Black and Brown, as well as a 4th wire which is the tach wire. Use this wire at any of the coils on the side of the engine.
 FUEL INJECTOR Opposite of Pink wire At any injector on engine   AC
 LOCK SEE NOTES
 The doorlocks are Class 2 Data on this vehicle and cannot be interfaced directly. Interface modules for both doorlocks and security are available for this vehicle. Contact your supplier for more information.
 UNLOCK SEE NOTES
 DOORPIN Gray/black At courtesy light under dash   +
 TRUNK PIN Pink/black At BCM in driver's side dash   -
 SE NOTE: This vehicle is equipped with GM's Passlock 2 passive anti-theft system. Please refer to the appropriate security diagram before any remote start installation.
 FACTORY ARM SEE NOTES
 FACTORY DISARM SEE NOTES
 BRAKESWITCH White At switch above brake pedal   +
 PARKLIGHTS Gray/black At connector on light switch assembly   -
 HORN Black At BCM in driver's side dash   -
 The BCM is located on the left side of the instrument cluster. The front dash panel must be removed to access it.
 HEADLIGHTS White At connector on light switch assembly   -
 VSS WIRE GREEN / WHITE Under hood, next to battery   AC
 DATABUS INTERFACE Pin-2(top row from left) Diagnostic plug below dash   DATA
 PASSLOCK DATA Yellow In 3 wire harness from ignition switch   DATA
 PASSLOCK GROUND Black or ORANGE / black In 3 wire harness from ignition switch   -
Tuesday, June 18, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
