vss and reverse wire on 2005 chevy astro
natocamp55
Posted: December 13, 2007 at 7:41 PM / IP Logged
I'm installing an Alpine nve-852 nav unit any tips on were to tap into for the VSS and reverse wire?
thanks
Renato
KarTuneMan
Platinum - Posts: 7,056
Posted: December 22, 2007 at 12:21 AM / IP Logged
HEADLIGHTS Yellow At light switch harness   +
 REVERSE LIGHTS Lt.green At steering column harness   +
 DIMMER Gray At dimmer switch harness
 VSS WIRE Dk.GREEN / WHITE At VCM on side of battery   4000ppm
 SE NOTE: This car is equipped with GM's PASSLOCK II. Please refer to our SECURITY diagram before any remote start installation. Please be sure to connect the second ignition wire for remote starting or the transmission computer will shut down and the check engine light will come on.
 DATABUS INTERFACE Pin-2(top row from left) Diagnostic plug below dash   DATA
 PASSLOCK DATA Yellow In 3 wire harness from ignition switch   DATA
 PASSLOCK GROUND ORANGE / black In 3 wire harness from ignition switch   -
