05 ford tauras keyless entry
swatpilot
Member - Posts: 8
Posted: December 31, 2007 at 5:24 PM / IP Logged
Im getting ready to install a keyless entry on a 05 ford tauras with power locks.  Im going to use a Viper 570T but just use the keyless entry part, they already have the unit and doesnt want the RS.  Is the a databus module that I can use that will control the doorlocks for easy install?
KarTuneMan
Platinum - Posts: 7,056
Posted: December 31, 2007 at 7:02 PM / IP Logged
No such luck on the lock module
12 VOLTS GREEN/ black and Yellow Ignition Switch harness   +
 IGNITION RED / lt.green Ignition Switch harness   +
 ACCESSORY Gray / YELLOW Ignition Switch harness   +
 ACCESSORY 2 BLACK/ green and RED / black Ignition Switch harness   +
 STARTER RED / blue Ignition Switch harness   +
 LOCK Pink / YELLOW In driver's kickpanel   -
 UNLOCK Pink/green In driver's kickpanel   -
swatpilot
Member - Posts: 8
Posted: December 31, 2007 at 10:03 PM / IP Logged
Thanks KartuneMan, and the lock and unlock is a straight (-) trigger, I dont have to use any relays, that makes it nice.
