putting speakers in foam
murree
Member - Posts: 8
Posted: January 11, 2008 at 11:01 AM / IP Logged
had an idea,
in my 06 lancer ralliart i have foam side bolsters on the back seat...
they're about 6inches thich so i though might be a good place for a set of speakers. as i'm thinking about taking them out of the rear shelf.
anyone have any tips on installing speakers in seat foam?
oh yea most likely will be 6.5's not sure if i'll use components or not...
and as i side question, is it bad to have a set of components front and rear?
Pioneer 5700 indash headunit
type R 6.5 coaxial
type R 6.5 components
2 - 10" premier TS-W106C
Pioneer GM-D510M mono
Clarion APX4240 4 channel
DYohn
Platinum - Posts: 10,741
Posted: January 11, 2008 at 11:12 AM / IP Logged
Speakers can generate quite a bit of heat so it is not a good idea to mount them directly into foam rubber.  You could certainly remove the foam and replace it with a glassed enclosure made into the same shape.
murree
Member - Posts: 8
Posted: January 11, 2008 at 2:50 PM / IP Logged
hmmm... might sound ghetto but what about PVC pipe? i'll take some pics of the peice should help a bit
type R 6.5 coaxial
speakermakers
Copper - Posts: 231
Posted: January 11, 2008 at 11:43 PM / IP Logged
I have my thoughts but I must first ask, What’s wrong with the rear shelf?
murree
Member - Posts: 8
Posted: January 12, 2008 at 7:47 PM / IP Logged
lol... it just vibrates alot... its really thin cheap particle board so it vibrates no to mention the plastic hardware attached to it vibrates like crazy...
i'd prefer if it was nothing but speakers and carpet back there...
ples i wanna have a set up that isn't like everyone elses...
either i remove the speakers and put them elsewhere, or make a fiberglass enclosure for the shelf for the 6.5's
is it bad to have more than one set of components in the cabin o rthe car?
type R 6.5 coaxial
