Wiring diagram for '88 Toyota Supra
kevindanielk
Member - Posts: 42
Posted: February 27, 2003 at 4:01 AM / IP Logged
Can anyone provide me with the wiring diagram for my 1988 Toyota Supra.
I am installing a DEI hornet 553t.
kevindanielk
Member - Posts: 42
Posted: February 27, 2003 at 4:25 AM / IP Logged
I am specifically looking to find the factory ARM wire for the Supra.
It is not included in the wire diagram supplied by THE 12 volt.
Thank you
tsupra
Posted: February 27, 2003 at 3:21 PM / IP Logged
what is it that you are trying to do with the factory alarm?
kevindanielk
Member - Posts: 42
Posted: February 27, 2003 at 6:25 PM / IP Logged
I am trying to disarm the factory alarm when i remote start the car.
The factory alarn comes on and i have to use my key to disarm it .
seanw
Member - Posts: 7
Posted: February 27, 2003 at 7:02 PM / IP Logged
the oem alarm disarm should be purple / YELLOW (-)in driver side kick panel
sean walsh
tsupra
Posted: February 27, 2003 at 10:22 PM / IP Logged
or you can open the hood and pop the cover off the hood pin, this is the little black plastic thing at the front right next to the latch. once the cover is off you'll see 2 wires going into the sensor, cut the 2 wires and wire them together. this will cause the alarm computer to think the hood is open which will prevent it from arming. just so you know this has been done by several hundred members of the supra owners group international which is where i learned of it.
kevindanielk
Member - Posts: 42
Posted: March 02, 2003 at 5:38 AM / IP Logged
THANK YOU FOR THE INFO.
seanw and tsupra
