Honda Transponder Bypass
illmattix
Member - Posts: 31
Posted: March 01, 2003 at 12:04 PM / IP Logged
I'm about to install a transponder bypass on a 2000 Honda Accord. I need to know where the connector is for the wires coming from the Honda immobilizer module. I think its a green 5 pin with 4 wires connector but i don't know where it is. Any help would be great.
jrilla
Gold - Posts: 1,498
Posted: March 01, 2003 at 1:43 PM / IP Logged
What immobolizer bypass and what car?
J Rilla
Owner/Installer
JWorm
Platinum - Posts: 2,208
Posted: March 01, 2003 at 4:47 PM / IP Logged
AH...I'm guessing 2000 Accord with a 555H.   The connector is at the top of the key cylinder. Remove the black plastic piece around the steering column to access. The "data" and "sync" wire colors will probably be red and blue. Key sense will be blue/white in the other plug near it. You can access the wires in the harness coming down from the ignition, but you won't know for sure what color they are unless you take apart the column. You can't test the data and sync wires, but you can test the keysense.
