seat heater, 2007 nissan murano
russbm
Member - Posts: 46
Posted: March 18, 2008 at 10:19 AM / IP Logged
Please need help on wiring diagram on a 2007 nissan murano installing seat heater on both driver and passenger seat in front. The ign 12v is a thin wire not sure about connected 2 15 amp fuse to that thin wire.
KarTuneMan
Platinum - Posts: 7,056
Posted: March 18, 2008 at 7:50 PM / IP Logged
Use an accesory.
russbm
Member - Posts: 46
Posted: March 19, 2008 at 8:13 AM / IP Logged
I am thinking of more of using a relay what is the method for this to wire what up.
KarTuneMan
Posted: March 20, 2008 at 9:17 AM / IP Logged
ok   ?
russbm
Member - Posts: 46
Posted: March 20, 2008 at 2:28 PM / IP Logged
why are you asking if the internet ever run out of room of course not they alway keep adding bigger server.
tedmond
Gold - Posts: 4,610
Posted: March 20, 2008 at 5:37 PM / IP Logged
well, thats just a signature and you can put anything. Hes not really serious with the question if you think about it. Kinda like a rheotorical question.
jim hunter
Silver - Posts: 351
Posted: March 22, 2008 at 11:38 AM / IP Logged
just use a relay, small gauge ignition wires only power bcms/relays therefore they are low voltage a relay as i described before is safest way running pin 86 to battery or heavy gauge power wire to ensure enough amperage as seat heaters usually have 7.5 amp fuses therefore you need to wire to allow for a maximum 15 amp draw as the manufacturers have done with their fuse capacity
chriswallace187
Gold - Posts: 1,661
Posted: March 22, 2008 at 12:01 PM / IP Logged
You could use a relay, however it'd need to be wired as follows:
85 - ground
86 - ignition 12v+
87 - battery
30 - power inputs to seat heaters
87a - N.C.
Also check out the wire gauge size guide if you haven't yet - make sure you're using a large enough size that the wire won't heat up.
C Renner's Auto Electronix
