04 chevy aveo, remote start
bak0707
Member - Posts: 38
Posted: March 25, 2008 at 9:44 PM / IP Logged
hey guys i need some help. my boss wants me to install a r/s in his wifes car and im not sure if it needs a bypass or not . i have read on some forums that some do and that some dont. i thought it does even though it is a base model. also he wants me to install power locks my other question is even if it does not have a power lock or unlock button do these cars come with power locks.  thank you
any help will be appreciated
spookiestylez
Silver - Posts: 531
Posted: March 25, 2008 at 10:23 PM / IP Logged
I have not worked on a newer chevy that did not need a bypass module, and to save the trouble get one anyways. I'd recommend the XK05 from bypasskit.com, or a retailer you can get a bypass from locally. I prefer to use bypass modules that dont require the "donation" of the key (universal bypass)like the directed 556UW module. As far as the power locks go, if the car did not come with the factory option included for power locks the only way you can add them is by adding 2 wire door lock actuators inside the doors.Then you can wire the actuators in the doors with a few relays ( or a 451m lock interface if you are installing a DEI product) to your r/s-keyless brain. There are tons of diagrams for this on the main page of the12volt.com, and for adding actuators also, but if you need anymore help post back or pm me.
Cheers
rtfm
Chris Luongo
Platinum - Posts: 3,746
Posted: March 26, 2008 at 6:26 AM / IP Logged
The Aveo is a Korean Daewoo, and does not have a transponder. No bypass needed.
You could install power doorlock actuators inside the doors. Actuators are fairly cheap (maybe $5-15 each, depending on where you buy), but are labor-intensive to install.
