karr secuity, 1994 honda accord
handyal
Posted: April 12, 2008 at 10:11 AM / IP Logged
I have a 1994 Honda Accord, The Karr alarm is not setting. I look under the dash, there is a wire from a 12volt ign on that came off from the alarm mod. the wire harness off the car is the loop where the starter bypass  is connected. There is also a wire from the mod. which white connected to acc on, that wire is still connected. Can you tell me what wire from the alarm mod. connect to that 12 volt source. Alarm is not setting. The alarm was original install from the car deal.
Thank you Allen
Allen Lew
KarTuneMan
Platinum - Posts: 7,056
Posted: April 13, 2008 at 12:35 AM / IP Logged
You push the lock/arm, and it does nothing...... correct.
If it locks and does not arm could it be in valet mode? (led on solid)
handyal
Posted: April 13, 2008 at 1:15 PM / IP Logged
thank you for your reply, But on the starter loop of the 94 Honda Accord, one the wires from the alarm mod came off the the harness of the car. On the Karr system mod. do you know wire is ign 1 and 2? one of those wire came off the car harness
Allen Lew
