VW radio removal tool?
mobileinstallat
Copper - Posts: 92
Posted: March 25, 2003 at 6:15 AM / IP Logged
2002 VW radio removal tool, anything special? The slots look like it takes just two flat tools. any discription on depth or holes in the factory tools? even a picture of them? I only just looked at the factory radio face gave an estimate and left the customer.
2) This same customer wants an XM tunner interfaced with his VW radio. The VW is a convertable, the sat ant for the XM unit fits nicely in the center arm rest, anyone ever try this location? The arm rest is all plastic and the top is a rag-top, so the signal should pass.
any info is appr,
Thanks men
Mark
esmith69
Gold - Posts: 1,511
Posted: March 25, 2003 at 10:05 AM / IP Logged
You need the vw/mercedes/audio removal tools--I prefer this particular style over the "keychain" style because these have three different ends to accomodate slightly different slot openings, whereas the keychain style only has the one type of end:  http://www.crutchfield.com/cgi-bin/S-ckfNR0xYsLd/ProdView.asp?s=0&c=11&g=754&I=120869001&o=m&a=0&cc=01&avf=N
The xm antenna must have at minimum a clear line of sight to the sky in order to function properly.  Technically it's also supposed to be mounted on a conductive surface like the body of the vehicle but occasionally you can get by without doing that.  Have you thought about the trunk?  Cuz that's probably the only place it'll fit unless he gets a glass mount antenna and mounts it just next to where the rear view mirror is, on the front of the windshield.
