trunk pin switch
slmgbr80
Member - Posts: 9
Posted: February 16, 2010 at 2:34 AM / IP Logged
i have a 97 honda civic ex at. i have a nitro bmw alarm installed but i wanted to add trunk feature i am wondering if this is possible. my trunk doesnt have a pop button for the trunk it has something that you pull. so do i need to install something else any advice would be appreciated.
plain man dwelling in tents
x1le
Copper - Posts: 171
Posted: February 16, 2010 at 7:35 AM / IP Logged
trunk solenoid!
Platinum - Posts: 13,726
Posted: February 16, 2010 at 8:15 AM / IP Logged
Exactly what trunk feature do you want to install?  A trigger wire to set the alarm off, as stated in the subject.  Or a trunk release solenoid, as asked about in your question?
slmgbr80
Member - Posts: 9
Posted: February 16, 2010 at 3:48 PM / IP Logged
A trunk release selenoid i want to pop it open with the remote
tedmond
Gold - Posts: 4,610
Posted: February 16, 2010 at 4:45 PM / IP Logged
you will need a trunk pop solenoid OR go to your local junk yard and look for a similar model (EX, or higher) and take the trunk release kit from that.
the EX or higher models with power locks, windows also had electronic trunk release.
Ted
Compustar Expert
Posted: February 16, 2010 at 5:13 PM / IP Logged
Time and effort wise, you'd be better off going Ted's route. Mounting an aftermarket trunk solenoid from scratch is a right PITA as regards positioning etc.
slmgbr80
Member - Posts: 9
Posted: February 17, 2010 at 12:11 AM / IP Logged
thanks guys for all your help ill try that
