magicar 902
palcal1
Posted: March 05, 2010 at 6:33 PM / IP Logged
Has anyone every put one of these in. I put it in and the door locks and all work but can not get the truck to start. When started with the key it would not turn off. Had to pull the fuse out of the magicar to get it to turn off. any idea on what i did wrong. Do you need to have the starter relay put in this.
Calvin
palcal1
Posted: March 05, 2010 at 6:38 PM / IP Logged
I put a magicar 902 in a 2008 F-150 pickup. The door locks work and the horn chrips. It will not start. When started with the key I could not turn the truck off. I had to pull the fuse out of the magicar to get it to turn off. I did not put the relay in the started. There was a yellow wire all ready to the started and could not see why I would need it. All I want is the truck to start and lock and unlock the doors. has any one put one of these units in before. Sure would like a little help on this thanks
Calvin
tedmond
Gold - Posts: 4,610
Posted: March 05, 2010 at 7:52 PM / IP Logged
you should check your wiring at the ignition. after you remove the key,
 open the door and close it. see if it turns off. if this is the case its set for manual tranny.
Ted
Compustar Expert
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
